Hi there guys,
Great forum, just tried recapping a functional Dell Gx745 sff motherboard (BTX motherboard and proprietary).
So... replaced 6.3V x 2200uF capacitors with new ones from Sayal Electronics here in toronto (Nichicon caps).
The computer runs fine.
HOWEVER, 2 of my new caps that I installed exhibit some mild "bulging" even before I powered up the system. I examined them all and tested them before installation with a multimeter so I knew they were at least visually good.
Are they bulging because I overheated them? Is this of significant enough concern that I should recap them again?
I used a 40watt Soldering iron to place on. Maybe should have used 40W to remove caps and 25 W to solder on.
Many thanks, I'm a newbie to motherboard recapping.
