VRM Mod cell phone app
    I found this Vmod Calculator in Google Play.
    https://play.google.com/store/apps/d...hl=en_US&gl=US
    It's for spoofing the CPU Voltage feedback signal pin VSENSE at the VRM controller chip. This works for GPUs also.
    Input CPU mV
    Resistance to GRD at the VSENSE pin.
    This produces a chart of CPU mV using various pulldown potentiometers installed there. Unless you install a readout Volt gauge you will have to rely on the chart beause the computer will think everything is normal. This could be useful for Pinmod overclocking of locked CPUs. Like 3.83GHz E7600 @333fsb.
    If you click around thereare a couple sample charts for 1.200V, and 1.45V starting points.
    Re: VRM Mod cell phone app
    Awesome
      This also lets you sneak past Intels silly 1.6V. VSEL limit.
        Did I forget to mention E7600 @ 400fsb X 11.5 = 4.6GHz
        The E7500 would be 4.4GHz, and is known to go 333fsb x 11 = 3.67GHz on stock Voltage.
        You can use Throttlestop to tune the multiplier back down if needed.
        The Dell T3400 workstation has X38 chipset with 400fsb support (unofficial).
