Re: Lenovo Y530 shuts off after few seconds
https://www.badcaps.net/forum/showpo...02&postcount=2
2.2. Don't suspect that something is shorted with no reason
Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
