Hello. I have a asus rz09-0329 here that has problems charging. Here are the symptoms:
-Will not charge while off, nor while in bios/bootup.
-Will not power on if the battery is disconnected.
-Powers on with the battery connected, with and without charger.
-Only charges while in Windows 10, but only if I disable the "Microsoft AC Adapter" device. If it is enabled, it says it is running on battery power only.
Funny thing: I can boot windows with the power supply and battery connected, turn off the laptop, disconect the battery (without unplugging the power supply), and boot up with the battery disconnected. But if I unplug the power supply, I can not get it to turn on without the battery connected.
I was thinking it might be the charge controller, it has an ISL95520HRZ, but I am not sure, and would have to order one from aliexpress just to test this theory. Any ideas?
I cant seem to find any schematics, which would help, nor the datasheet for the controller, only a 1 page document on how it works, with no pinout. But being that it does charge while in windows, I am thinking it might not be the controller, but whatever communicates with it.
