Acer Nitro 5 AN517-54 LA-L181P
    BAADNB
    Chip Masked Need Chip actual Chip Info.
    Need motherboard schematics or the chip info.
    Re: Acer Nitro 5 AN517-54 LA-L181P
    p/n Silergy SY8286RAC
    Source from Aliexpress.
    Datasheet is attached.
    Here is a store we use:
    https://www.aliexpress.com/item/3290...d=J0vDSjppbf4G
    PS: Share the full markings from your device so that the vendor can confirm the replacement will function as per the original part.
    Comment: The above p/n is a match for your damaged device but the attached PDF as an 'A' as a suffix so there may be a small difference in the datasheet.
      The datasheet is here https://www.silergy.com/cn/productsview/SY8286RAC Marking BAA***
      It wasn`t available the last time i checked. https://www.badcaps.net/forum/showpo...1&postcount=12
      @mon2 wins the LG wireless earbuds
        Thank you @SMDFlea. I will cherish the prize and do not wish to forfeit them but do we know if:
        The RAC is the same as the "ARAC" version?
        The datasheet is for the ARAC. The actual component is the RAC.
        The AliExpress stores reference the RAC version.
          The RAC and ARAC are different.The RAC pin 12 is not connected .
          The ARAC is marked AWR.
          The Ali part you referenced is the right one
