Hi ya'll I got a tv that is completely dead here. I opened the back to see bulging caps on the psu. Anybody have any good prices for some high quality low esr caps for this sucker?
PN43D450A2DXZA Samsung Plasma DEAD
Re: PN43D450A2DXZA Samsung Plasma DEAD
Yes Sir I Actually plan on doing that I just want to verify the set works then I will try my luck on ebay low esr caps ya know? I will replace caps with proper spec and low esr and new when set is proven to be worth putting money into sir. I bought a new mainboard not psu as there was a shorted fet on the motherboard that would reach like 170 farenheit just plugged in for 30 seconds. So I bought a used cheap modbo on ebay. I will update you guys.
When you are running the test patterns, you are not using the mainboard. This test will prove if the mainboard is good or not. Why not replace every board in the tv to make sure it doesn't have a bad panel....cause it's a waste of money. Am I right? If you don't want to take our advice then why bother.
I knew it was the motherboard because one of the mosfets in my second post on this thread shows right above hdmi 2. It was getting so hot that it would burn my hands just being plugged in. It had to be shorted. My fix was a $10 used ebay motherboard on ebay good deal and it worked a treat. Now I'm just gonna do some preventive maintmance and replace some of the caps I feel are important ie standby psu caps.
