Asus MK241H no power
    Re: Asus MK241H no power
    Thank you very much. I will look into it.
    Yesteday I have sent a private message to the person who gave me the resistor values, but I don't have much hope that he will answer.
    Which transistor is the Q101? Which one did you buy?
      Never mind, the transistor I have replaced already a while back.
        CORRECTION! In the previous post, I said that R172 was .01 ohm. I should have said 0.1 ohms - still 2 watt. BTW the SMT resistors are 805.
          Ignore last post - brain fart. Original post was correct. For Q101 I used an STF18NM60N.
            I have ordered 0.1 Ohm/2W resistor.
            I'm waiting for the parts to arrive.
            I don't know how come I haven't checked this resistor, it's so obvious that is open, I can actually see a piece blown from it.
            I was concentrating so much on the SMD parts, that I have forgot to actually look on the other side of the board for bad through hole components.
              I have replaced the mentioned components and there is no change.
              The only voltage I'm getting is the 166V, nothing else.
              The TEA chip is not getting the right Vcc(which I don't know how much it should be), it's only getting 1.8V. At the pin 8 I have 141V.
                I have looked at the TEA pdf and there it is mentioned that the Vcc is getting from the transformer after the PS is started.
                So this IC won't start only after the PS is started.
                I must have another problem that is causing to not start.
                At the output connector that goes to the mainboard, I'm not getting almost anything. On some of the pins I'm getting less then 0.5V.
                Should I have standby voltage? No light turns on, when plugged in.
                  Nobody can help?
                    Nobody can explain to me what should be happening with this PS to be able to start?
                    It should have a standby voltage? On the output connector toward the mainboard, nothing is printed on the board.
                      I have just gave up and purchased a new board from Ebay ($49.90), put it in and it's working great.
                      The only check I have done is to make sure that we had the right resistors and we did.
                      It's a nice monitor, with webcam, speaker, HDMI input.
                        Hi, I have problem with the same asus display. No power, no stby, no led. I found broken D115 Schootky Diode mbrf20200ct. Replace it and now display works!
                        Sorry for my poor english.
                          I have removed that diode and measured it and it conducts in one way and doesn't conduct the other way. That is good? It shouldn't conduct a bit the other way?
                            you saved my head from burning
