I've been trying unsuccessfully to resurrect my 2493hm reading throught
badcaps.net
It started like that: I tried to switch it on and heard "pschtt" and the screen went immediately black.
The symptoms are the following: No image, the blue led stays stable, the 2493hm can be switched on & off from the front panel.
When telling in several stores that the screen was only 4 years old when it went dead I was told: "Sir, nowadays, most of the screens & tv last an average of 2 to 3 years..."
THAT annoyed me a bit and I'd like to prove them wrong !
Attached are the photos of the logic board & power supply.
The following threads helped me for the following below:
https://www.badcaps.net/forum/showthread.php?t=15796
https://www.badcaps.net/forum/showthread.php?t=15843
https://www.badcaps.net/forum/showthread.php?t=13366
Power supply BN44-00195A.
-The fuses are good (tested continuity)
I've changed all the electrolytic capacitors except the 82uF/450V.
connector CN852(BL/SOS/A_DIM/ST D_DIM/DBT):
Connector CN851(S_B/NC*3/GND*3/5.4V*3/NC*2):
Connector CN85 (ST/P_DIM/ADIM/SOS/GND/+24V):
MC33067P ICM801
Using pin 4 as ground:
Using pin 13 as ground:
At the back of the PCB near that MC33067P, I checked a few resistors:
STRA6159 chip ICB801S
A few resistor a the back near the STRA6159 chip:
RB816 99,45K Ohms
RB815 2,19K Ohms
RB813 4,16K Ohms
Tested in-circuit (power off):
RB??? (next to the RB802) 98,94 KOhms (brown black yellow gold)
RB802 98,70 kOhms (brown black yellow gold)
RB803 46,23 Ohms (yellow purple black silver)
RB808 2,2 Ohms (red black gold gold)
RB801S 33,08 Ohms (yellow yellow black gold white)
RX801S 750 kOhms (purple green, yellow kaki black)
RW801 0,5 Ohms (red red silver gold)
Logic board BN41-00962A:
I checked the following:
IC113 LF25:
IC305 6P807
Could the STRA6159 be bad ? Should I change it or check something else ?
Thanks in advance for your help !
Yves
badcaps.net
Code:
Pin OFF ON DBT 0,2 0,2 ST/P_DIM 0 0 A_DIM 0 0 SOS 0 0 BL 0 0
Code:
Pin OFF ON PS_? 0 3,147 S_B 5,24 5,24 GND 0 0 NC 0 0 GND 0 0 5.4V 0,45 0,45 NC 0 0
Code:
Pin OFF ON ST/P_DIM 0 0 ADIM 0 0 SOS 0 0 GND 0 0 +24V 0 0,5
Code:
Pin OFF ON 1 0,01 5,05 2 0 5,05 3 0 2,54 4 0 0 5 0 5,08 6 0 0,06 7 0 0,06 8 0 5,05 9 0,03 14,62 10 0 0 11 0 0,19 12 0 14,05 13 0 0 14 0,01 0,32 15 0,04 15 16 0 5,04
Code:
Pin OFF ON 14 0,01 0,35 12 0 13,91
Code:
Pins OFF ON 3-1 0 0,02 3-2 14,44 16,51 3-3 0 0 3-4 0,44 1,09 3-5 315 385 <-- seems strange ?
RB816 99,45K Ohms
RB815 2,19K Ohms
RB813 4,16K Ohms
IC113 LF25:
Code:
Pin ON OFF 1 3,25 3,25 2 0 0 3 2,5 2,5
Code:
Pin ON OFF 1 5,22 5,22 2 0 0 3 5,21 5,21
Yves
