Original Xbox Replacement Caps
    Re: Original Xbox Replacement Caps
    Otherwise, there is no 3x 6.3v 3300uf Nichicon HM (10x25mm) good for my mobo for sale somewhere ?
    Why to buy 5X 1000μF 6.3V instead 3X 3x 6.3v 3300uf Nichicon HM (10x25mm) ?
      nobody makes ultra-low esr electrolytic caps anymore, poly's replaced them several years ago.
      if you found someone selling Nichicon HM or Rubycon MBZ / MCZ or Panasonic FL, they would be very old stock.
        I see ! Can you give me your feedback once you have tried those 5 capa you linked me ?
        So then i can buy them 100% sure.
        Thanks again for you precious help =)
          i will post results and pictures
              fitted.
              not tested yet, i need to find a video cable & backup the harddrive.
                Cool ! Thanks for the photo !
                Take your time, i'm not in the hurry ! =)
                  I also have to replace the caps 3300uF 6.3v in my v1.3 motherboard. I'm in Australia which makes it slightly more difficult to find the correct caps. Can anyone point me in the right direction? Cheers
                    where can you buy parts in oz??
                      RS Components or Element14
                        not a problem then.
                          Yer cool. I'm not sure then which ones I should be getting or what to look for to make sure they are suitable? Any recommendations? Thanks
                            https://www.badcaps.net/forum/showpo...0&postcount=53
                            CONFIRMED WORKING.
                              Thanks! I ordered some now.
                                So you tested it and it worked stj ?
                                If yes, i will order the caps this evening ! Thanks again, it seems like you will save 3 Xbox instead of just one !
                                  3?
                                  each xbox needs 5 caps. - even if you originally had 3 you still fit 5 because they are a lower uf value.
                                  so each pack saves 2 xboxes.
                                  and i played Burnout3 on it - a good test.
                                    No i mean, with your advices and help, 3 Xbox (yours, Travjzx and mine) will be saved ! =)
                                    Thanks ! I will order now !
                                      Sadly, RS-online doesn't send to France
                                      Do you know another website i could buy these caps ?
                                        I think i found: https://befr.rs-online.com/web/p/alu...itors/7149553/
                                          But i dont understand, it seems like on this website, only professionnal can buy, it asks me the name of my society but i don't have one !
                                          And sadly, now on this european version of RS, i have shipping cost to pay
