I had to replace the Vram on an asus rog gl502vm gpu gtx 1060 card.
The original memories is micron D9TCB -> MT51J256M32HF-80 having an identical card that used samsung GDDR5
K4G41325FE-HC28 so I swapped them.
The notebook displays but GPUZ returns 0 G and microns as the memory brand ??? (as is possible that appears micron if I changed the memory ?)
I re-soldered the microns and the notebook works well for a few hours then (probably after some updates) I have a memory conflict that close any game I use but not performance test.
GPUZ tells me I have 6G of vram while a vram test program tells me I have 3G and it stopped the test . The firmware of the video card has been replaced, with a hex editor I know it is for the right model of rog but I cannot find information on the supported giga or the supported brand memories (how do you get this information from a graphic bios?) now I'm a little confused about the density of these chips:
1 D9TCB -> MT51J256M32HF-80 = 1G each chip ??
2 K4G41325FE-HC28 = 1G each chip ??
I would like to know for sure the amount of memory installed as the GPU firmware may be wrong
