Hello! After a thunderstorm, VGA and HDMI interfaces stopped working. DVI interface works, but with color distortion: pink instead of white. I did not find any diagrams or boardview on the Internet. Where should you look? Thank you!
After a thunderstorm, the Palit GeForce GT-240 video card
Re: After a thunderstorm, the Palit GeForce GT-240 video card
Was this a PC connected to a TV/monitor with external cable/antenna connections?
If so, what likely happened is the cable/antenna shield picked up an induced voltage from a nearby hit.
This then came down the antenna cable, into the TV.
Many newer sets do not have a GND wire in their power cord; in this case, the charge picked up by the antenna/cable has no other place to equalize except going to GND via the GND wire (to the electric service) of the PC.
The overall path is down the cable shield, into the TV chassis, up the HDMI into the video card, into the PC chassis, and finally, into the PC's power supply and out the GND wire towards the GND of the building's electric service, where the outside lines are attached. Some of the old wiring didn't have provisions to tie together (bond) all the GNDs (power, phone arrestor, cable/antenna), which results in them rising & falling unequally during storms.
In the US, such bonding jumpers are required per NEC. It's always easy to spot houses without such a jumper, because every spring the same houses have TVs damaged after every "first thunderstorm." That is, until the bonding jumper is installed.
While there are (significant) differences in how secondary voltages are derived in the US vs RU & UA, the bonding principles should mostly apply; HDMI is the coal mine canary, always damaged with poor bonding.
See attached PDF for clarity, especially Fig 800-23.Attached Files"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
First suspect would be TVS diodes.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Good afternoon guys! Sorry, I got sick a little, did not immediately answer. Upon closer inspection of the board from the reverse side, I found missing elements. I'll take a photo later and post it. But to find out exactly what elements are missing and what their values are, you need a diagram of this video card, or rather a boardview.
