MacBook Pro Retina Late 2013 shows light, fan spin but no chime
    Re: MacBook Pro Retina Late 2013 shows light, fan spin but no chime
    L7095, pin # 2.
    If that is indeed 3v42, then suggest to check the voltage on each coil on the logic board. Report any low / 0 volt readings.
      PP3V42_G3H_REG tested on L7095 pin 2: 3.42V
        Hi mon2,
        Can you help me make these readings?
        Many thanks.
          Attach a usb mouse. Allow the board to power up and wait a minute or so. Does the usb mouse light up?
            I do not have any wired USB mouse
            I plug in keyboard with USB receiver.
            I can see that keyboard is connecting to USB receiver as connecting light goes out.
              Measure the voltage of PM_BATLOW_L .
              Check it @ Q3000 - pin # 3.
                00.8 on 200m mode.
                  Sorry is bad reading, I measured at R2140 pin 1 and showing 3.3V
                    Correction: R1240 - good voltage.
                    Confirm the voltage again of PM_SLP_S4_L
                      3.3v.
                        Good.
                        See attached. Check each of the signals from this chart to confirm which one is still at '0' logic level.
                        When each is '1' -> the board should boot = S0 power state.
                          Hi mon2,
                          Please can you help me understand this chart and what I am testing, please for your help.
                            Search for each of the signal (net) names in the attached chart.
                            Measure their values and post them here. If the voltage is ~3v = '1'; then this is a good reading.
                            If the voltage is low = '0' -> stopping your board from booting up.
                            For the S0 power state, each of the highlighted signals need to be '1'.
                              Isolate_cpu mem_l: 3.3v
                              plt reset_l: 3.33v
                              pm_slp_s3_l: 0.00v
                              pm_slp_s4_l: 3.33v
                              cpu_mem_reset_l: 1.35v
                              mem_reset_l: 1.35v
                              memvtt_en: 0.01v
                              cpuvddq_en: 0.00v
                                I am not sure what happened but I re-tested all above again and now:
                                Isolate_cpu mem_l: 0.00V
                                plt reset_l: 0.00V
                                pm_slp_s3_l: 0.00V
                                pm_slp_s4_l: 0.00V
                                cpu_mem_reset_l: 0.00V
                                mem_reset_l: 0.00V
                                memvtt_en: 0.00V
                                cpuvddq_en: 0.00V
                                  Will have to start from the beginning.
                                  Check PPBUS_G3H.
                                    Originally posted by mon2 View Post
                                    will have to start from the beginning.
                                    Check ppbus_g3h.
                                    12.59v
                                      Hi mon2,
                                      ALL_SYS_PWRGD is measuring as 3.19V, how can system not boot?
                                        Now fan started spinning again!
                                        It's spinning like jet engine when power connected but still no boot
                                          Okay with fan spinning ALL_SYS_PWRGD 3.19V.
                                          But it's intermittent, now fan stopped spinning and ALL_SYS_PWRGD 0.00V!
                                          So it looks like some fault on the board? But even when ALL_SYS_PWRGD is good, still no boot. Seems like stuck in SMC_BYPASS with full fan spin like jet engine?
