EPK50 LA-G07DP schematics
    I need schematics for this model BOARD ID: EPK50 LA-G07DP REV 1.0 please
    Re: hp 15-a0007nx schematics
    No schematic available.
      too bad there is no schematic for this model available i have attached the ic that is shorted
        Start a new thread in the main laptop forum, with clearer pictures and any part numbers you can get from the IC.
          check this
            Thank you zameer
              Same problem, when i press the power button, PU301 ic has over heat then voltage drop on IO ic pin no 33, and also no voltage send to BIOS pin 3.40v,
              <kavinharryjo>
              how do find out this ic has short? //kavinharryjo//
              equalant ic is AWVBJR and search this SY8286BRAC_QFN20_3X3 . search listed items are working properly //kavinharryjo
                Re: hp 15-a0007nx LA-G07DP schematics
                AND Also working this ic AWW81B. Thats used for when we press the power button Its send 4.5 voltage to BIOS ic
                  Thank you
                    thank you zameer
                      Originally posted by zameer View Post
                      check this
                      Thank you
                        thanks
                          I have one of these motherboards that has the same problem with PU301. The chip doesn't seem to be shorted however I have no 3.3V output from it resulting in no 3.3V at the super IO chip or the power button. Has anyone had success replacing PU301 and getting the board working?
                          If I apply 3.3V directly to jumper PJ303, the board will come on so I know there isn't a bad capacitor or something dragging the 3.3V output down.
                            Thanks a lot, zameer, and happy new year!.
                              Re: HP 250 G7 EPW50 LA-G07FP Schematic
                              Here I found for EPK50 LA-G07DP REV 1.0 BoardView
                                Is it so hard to attach the file in your post, instead of linking to external site?
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                  Re: EPK50 LA-G07DP schematics
                                  Please I need the schematic for EPK50 LA-G07DP
                                    You might find the elusive schematic if you read the whole thread
