Looking for motherboard LA-E841P schematics
    I need this schematics urgent !
    Thank you guys.
    Motheboard :
    CTL51/53 LA-E841P
    Rev : 2.0
    Re: Looking for motherboard LA-E841P schematics
    Anyone,please !
      please
        SOMEONE WILL BE ABLE TO HELP ME WITH THIS SCHEMATIC LA-E841p
          Re: Need bios hp la-e841p
          I need schecamtics for CTL51/53 LA841P Rev:2.0 '
            ctl 51/53 la-e841p schematics please
              Please someone I am urgently looking for la-e841p board schematics.
                La-e841p
                Hi. LA-E841P rev:2.0
                i need kbc connection scheme .kbc programming.(ene )
                thanks.
                  Re: La-e841p
                  thanks.
                  LA-E841P KB_pins=32 LEFT DOWN 1MM KSO3=15 KSI4=28 KSI7=31 KSI6=30 KSI5=27
                    Re: La-e841p
                    thanksssss.
                      Thank you guys.
                      Motheboard :
                      CTL51/53 LA-E841P
                      Rev : 2.0
                      Good morning friend, I would like you to help me with the same schematics CTL51 / 53 LA-E841P because if you managed to find it, thank you
                      Last edited by SMDFlea; 06-03-2021, 11:00 AM. Reason: https://translate.google.com
                        thanks SMDFlea
                          Still no schematics available?
                          I have one just with led on charging socket,white without battery and yellow with battery.
                          Power button get 3.3V and drop to 0 when pressed,but no visible reaction.
                          After investigation I found one knocked off capacitor on Vcc line of RT3661AB,datasheet say at least 2.2uF,replaced with 10uF
                          When power button pressed RT3661 get 5V
                          But missing power on BIOS chip.
                          Further investigation revealed some corossion on one resistor chip array 4x100K and one of resistor damaged,replaced that.After that I get 1.8V on pin 8 of BIOS chip.
                          Now when I press power button,fan start,at all coils of DC-DC converter I have some voltage but fan speed go to max and caps blink in sequence
                          5 long and 3 shorts blinks.
                            Available on some paid sites now .
                              Would be greatefull if you could PM me the site or just write it here, since i honestly cant find it anywhere nor paid nor free
                                https://***************************chematic/
                                  I need scamatic
                                    Requires shematic to convert to uma please help
                                      plase help
                                        if you have shematic for this board
