need dell latitude e4300 bios dump
    someone could post dell latitude e4300 pp13s full bios dump
    thank
    Re: need dell latitude e4300 bios dump
    someone please
      I AHVE TRIED BUT UNABLE TO FIND THE REQUIRED FILE
      BUT MAY THE FOLLOWING WILL HELP YOU
      Re: Help To extract Dell EXE BIOS
      I'm not sure exactly what you want, but I'm guessing that you cannot boot the laptop even into BIOS mode because the BIOS is corrupt.
      Which laptop?
      Most laptops (actually, most BIOSs) have an emergency recovery mode whereby it is possible to force a BIOS update even if the system cannot boot.
      Try this:
      Download the required BIOS file; let's call it x.exe
      Extract the HDR file from the x.exe with: "x.exe -writehdrfile". This will give a file x.hdr
      Copy x.hdr to a formatted diskette, perhaps on a USB-diskette (might even work on a pen drive)
      Rename x.hdr according to the list below
      Unplug the adapter and remove the battery from the laptop
      Hold "END" down on the keyboard while you plugin the Adapter
      The battery light should come on red
      Release "END" - the laptop power should up
      Wait while the diskette is read, this might take some time (you'll hear it)
      The laptop should shut down or restart itself
      Job done!
      Dell Latitude D410 : VENI???.BIN, VENI???.HDR, VENI???.HDC, VEN????.BIN, VEN????.HDR
      Dell Latitude D420 : CRO????.bin, CRO????.hdr, CRO????.hdc, D420???.bin, D420???.hdr
      Dell Latitude D430 : CAR????.bin, CAR????.hdr, CAR????.hdc, D430???.bin, D430???.hdr
      Dell Latitude D610 : AZED???.bin, AZED???.hdr, AZED???.hdc, AZE????.bin, AZE????.hdr
      Dell Latitude D620 : TRAV???.bin, TRAV???.hdr, TRAV???.hdc, D620???.bin, D620???.hdr
      Dell Latitude D630 : BRIS???.bin, BRIS???.hdr, BRIS???.hdc, D630???.bin, D630???.hdr
      Dell Latitude E4300 : LOLA???.bin, LOLA???.hdr, LOLA???.hdc, E4300??.bin, E4300??.hdr
      Dell Latitude E6400 : RSH????.bin, RSH????.hdr, RSH????.hdc, E6400??.bin, E6400??.hdr
      If your laptop is not listed, try google.
          read your old bios and post here, i might help you
          Im Back... sort of...
            old bios full backup
              i found this
              E4300A26.exe /Writeromfile
              E4300A26.exe /Writehdrfile
              The Win32 exe file will execute in windows and It will then create a BiosFileName.ROM or BiosFileName.HDR in the current Directory
              Further command line options are as bellow.
              Classic
              Reportstatus
              Norburesults
              Rburesults
              Writeromfile
              Writehexfile
              Writehdrfile
              Wipeclean
              Wipeall
              Verbose
              Prgboot
              Noreboot
              Nopause
              Info
              Forcetype
              Forceit
              Factory
              Edvu
              Boot
              after looking and rebuilding your dump, result is the same file, same CRC, so 99% not bios problem
                Dell Latitude E4300 BIOS need
                I need BIOS BIN for Dell Latitude E4300
                MOBO : JAL10 LA-4151P REV: 1.0
                  Re: Dell Latitude E4300 BIOS need
                  Your file is badly damaged and cannot be recovered. This file was found via google search.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Thanks but not working to me
