Bios file for Toshiba Tecra R950/R940
    Attached below is another (very) hard to find bios with 5MB ME firmware for Toshiba Tecra R950. Bios file is OK for Toshiba Tecra R940 too. With Clean ME ready to flash. Compiled and tested by me.
    Enjoy.
    Become a Badcaps supporter
    Thanks to all supporters.​
    need bios toshiba tecra r940
    hi i need bios toshiba tecra r940
    motherboard fam2sy2 a3256a
    thanks
      Re: Bios file for Toshiba Tecra R950/R940
      What doesn't suit you about the already posted above file?
        Received an old Tecra R950-1JX laptop with SVP password on it. I read the 8MB flash and upload here if somebody can help me to remove SVP password as I tried this file that Vesko356 uploaded but the laptop again asked for password.
        Or Challenge response code below:
        PC SERIAL 3D042765H
        CHALLENGE CODE: 3U34M-0A6YM-MA9Q0-5FDF5-B12UL
        Thanks in advance for help
          Originally posted by ordinateur View Post
          Received an old Tecra R950-1JX laptop with SVP...
          Please read the rules before posting:
          BIOS guides, methods, resources and tools
          Password removal by laptop brand
          Originally posted by piernov
          3.10. Toshiba
          3.10.1. Consumer
          A lot of Toshiba consumer laptops have a jumper on the motherboard that needs to be shorted before boot to clear the password.
          3.10.2. Business
          Most Toshiba business laptops do not have a jumper, and the password is stored inside a protected region of the EC. See affected models: https://www.badcaps.net/forum/showpo...2&postcount=19
          Either you need a donor EC without password, or you need to unlock through challenge-response.
          Response generator is not available publicly, however, some generous people may be able to generate a response for you. Ask in this thread: https://www.badcaps.net/forum/showthread.php?t=79489
          Laptop must not be rebooted, the challenge will change.
          Originally posted by SMDFlea View Post
          The password is stored in the SMSC MEC chip,it can`t be programmed as JTAG access is blocked. The only way to remove it is by challenge-response code or by using another chip from a donor board that has no pass.
          For information ... all these models are unlocked only through the response code:
          Portege (A30, A600, M100, M200, M300, M400, M700, M750, M780, R30-A, R100, R200, R400, R500, R600, R700, R830, R930, S100, Z830, Z930, Z10T-A, Z20T-B, Z30T-A/B/C, X20W-D, X30-D)
          Qosmio (F20, F30, F60, F750, G10, G20, G30, G40, G50)
          Satellite (M30, R10, R20, R630, R830, R840, R850, R930, Z930, U200, U920, Z30-A)
          Satellite Pro (A30-D, A40-D, A50, A120, M10, M30, R40-D, R50-B/C/D, R840, R850, R950, S200, S300, S300L, S500, U200)
          Tecra (A3X, A9, A10, A11, A40-D, A50, A50-D, C50-C, M1, M2, M3, M4, M5, M7, M9, M10, M11, R840, R850, R940, R950, S3, S4, S5, S10, S11, X40-D, W50- A, Z40T-A/B/C, Z50-A/B/C/D), WT310, Kira, Libretto (U100, W100)
          If you post your challenge code someone might give you the response code if you`re lucky.Otherwise you can find paid services if you google search for them.
