Hp smps power suppy ps4321 help!!!!!!
    Dear all
    i have several power supplies that when the transformer is connected on board
    secondary pins are all shorted (7pins).
    by removing it pins 1 and 5 are shown short and 2,3,4,6,7 are shorted between them.
    i tried to find datasheet but nothing. ps is manufactured by LITEON
    CAN ANYONE HELP!
    THANKS.
    ON PS I HAVE 4.3V ON POWER SWITCH ON
    Re: Hp smps power suppy ps4321 help!!!!!!
    It is a high frequency transformer, you can't ohm measure it.
    You need to use a transformer tester like a ring test, can also be done with an Oscilloscope if you Google for it.
      Sometimes a ring tester does not always read the winding correctly if there not very many turns on a winding I have run into this type of issue I have seen where the two red LEDs are light or in the yellow and the transformer is still working
      9 PC LCD Monitor
      6 LCD Flat Screen TV
      1 Dell Mother Board
      15 Computer Power Supply
      All of these had CAPs POOF
        Thanks for your message.
        i have noticed when transformer is installed on board and leave it rest for some time without power i get a very small resistance which means is not short but power supply has 4.3-4.5v stb voltage and is not turning on.
        there is PS25A and TL594 ic on secondary side which are not short.
        i checked all diodes and capacitors and non of them seem to be short.
        there is a transistor near the 3 optocouplers on which i get the 2.45v
        on the optocouplers on secondary side first one reads 0v and the other 2 read 10.8 to 11.5v.
        i removed optocoupler primary side and i placed diode instead to see if there is getting something HOT but nothing.
        do you have any ideas.
          Change out the caps for the 5VSB rail.
            The 5vsb and 12v ca0s have been replaced
