Need advice - hot tweezers under 300 usd
    Hi folks, i really need dvice about hot tweezers for soldering smd
    I need them really bad to speed up the work but those that i like costs a little bit too much :
    JBC CP-2QF
    https://kaisertech.co.uk/jbc-cpd-mic...dering-station
    Maybe someone also has that kind of dilemma and has found something a little bit cheaper ?
    I will be really grateful for a help.
    Or maybe someone is rich enough and want to give me a gift ...i will give you address for the shipment
    Have a great day
    Re: Need advice - hot tweezers under 300 usd
    Do you want something that is micro in size because you can find a large version for probably less money and have different options for the tips
    Thanks for wanting advice for hot tweezers I found some for my soldering station that I like to use a lot but I have to maybe modify it slightly for it to work correctly with my setup
    Look on EBay for some there some different type of these tweezers but I would highly recommend that you buy one that is temperature controlled for best results
    Here is what I just bought from EBay
    https://www.ebay.com/itm/39403986360...53.m2749.l2649
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
