Are these devices any good ( 5" TFT LCD Monitor Reversing Truck 4Pin Camera feed back
    I think about buying one are these devices worth the money
    https://www.ebay.com/itm/36364762849...3ABFBMjKuF3Zxg
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Are these devices any good ( 5" TFT LCD Monitor Reversing Truck 4Pin Camera feed
    I guess they are cheap enough. Some of the cheap cams, the clear plastic rots fast.
      That just great …—>
      …—>are the more expensive ones any better than this because if not then I will look for the cheapest one that I can find
      I really more interested in the monitor than anything else are they any good or are poor quality as well and are the more expensive ones any better
      9 PC LCD Monitor
      1 Dell Mother Board
        UV will kill most plastic very fast.
        if you can put it behind glass then most UVB/C will be blocked
          Originally posted by sam_sam_sam View Post
          That just great …—>
          To be honest, I'd look for something else, as the specs don't rock my socks.
            9 PC LCD Monitor
            1 Dell Mother Board
              There's many different cameras out now i.e. https://www.ebay.com/itm/363081107479
              I use the smaller $5 camera like this (with parking lines) and it's very good https://www.ebay.com/itm/114262648935 small easy to mount, metal case and no need for IR LED's, it does fine at night.
                Can you recommend a monitor that is decent quality that is what I am also looking for thanks
                9 PC LCD Monitor
                1 Dell Mother Board
                  I'm using the NAV's screen, have not tried any 5" mini monitors. 7" are about the same price. They seem to be 640x480 or 720x1280 or 800x480 resolution.
                  Tons of fake specs i.e IPS, 30 million pixels or 1080HD etc. Most of the time the spec is just left out of the ad.
                  The cameras are typically 1/4" VGA 640x480 0.3MP with analog video output. There are some with WiFi so you could use your phone/tablet as the screen.
