Old 08-22-2021, 05:54 PM   #1
SsimoR
City & State: Welland
My Country: Canada
Default 50t32-soc xl bd short
Hi everyone.
I have a 50" Toshiba tv that's showing vertical bars. I checked the t-con voltages and got vgh 24V and vgl -10V anyways I changed it with a good working t-con. I still have the same issue. I checked 50t32-soc xl bd and found a 100ohm resistor fried so I changed it. started the tv and it worked and I can see the logo...... but in a couple of seconds the same resistor got burned. I checked the rest of the resistors and capacitors, transistors and they're all seems to be good...Any idea what else can I do to try and solve this problem? Thank you!
SsimoR is offline   Reply With Quote
Old 08-24-2021, 09:36 AM   #2
SsimoR
My Country: Canada
Default Re: 50t32-soc xl bd short
It's ok, I got it fixed. Tv is up and running great!
Old 10-23-2021, 08:11 PM   #3
skynetronics
City & State: Santiago
My Country: Chile
Hey mate, what you did to solve the problem?
I have the same R075 (100 ohm) open. The other components seems normal (transistors, capacitors, etc).
PS: I'm from Chile and the problem is in an AOC, model LE50U7970, same panel with the same symptoms.
skynetronics is offline   Reply With Quote
Old 05-20-2022, 12:35 AM   #4
zinzin54
City & State: LANTON
My Country: France
I see you have the same problem as me. I have the 100 ohms resistor which is open, R082 on the 50T32-SOC XR ( the other board). So i change it but the problem is the same. I haven't time to investigate more. I think to see again this week-end. SsimoR solved the problem. Could you tell how you solved it please ?
Thank you.
zinzin54 is offline   Reply With Quote
Old 05-20-2022, 12:29 PM   #5
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
You got to love when people don't post how they fixed a problem.
So remove that resistor check from shorted pad and locate shorts then remove one at a time until short goes away.
dskall is offline   Reply With Quote
Old 05-20-2022, 01:39 PM   #6
kasfamily
kasfamily's Avatar
City & State: Vologda
My Country: Russia
Line Voltage: 230VAC 50Hz
https://youtu.be/ht1VBTlzbUo
kasfamily is offline   Reply With Quote
