MSI aero GTX 1070 voltage gone after a while
    Hello guys
    As the title says
    All voltages present,
    GPU vcore 0.8
    memory 1.5
    PEX 1.0
    1.8 volt
    5.0 volt
    Regardless GPU not detected and after a while (>20 sec) whole rails shut down. No short found
    Any idea what could be the issue ?
    Re: MSI aero GTX 1070 voltage gone after a while
    Does 5v dissappear too? Gpu not overheating is it?
      Yeah. GPU didn't overheat, I kept my finger on it all the time.
      I don't know which rail went out first, but yeah 5 volt definitely dissapeared/ switched off.
        Surely something wrong with the 5v regulator then?
          Probably. But I don't know which one is that.
            The one with 5v on
            Me neither, probably one of those coils on the back of the card.
              Oh please ......
              There are no coils with 5 volt. So prolly it is linear regulator, the catch is I only have around 20 secs window before it shuts down. Like playing cat and mouse
              I hope there is somebody who knows....
                Maybe this helps?
                  I was wrong the chip which generates 5v is mp1475
                    I tested this on egpu box. That 5volt chip shuts down because after a while 3.3 volt supply is killed, which feeds to it's EN signal,
                    3.3v rail is supplied from PCIe pin.
                    Egpu box works normally, confirmed with other GPU, flawless
                    Oscillator beside GPU chip works fine, confirmed using scope
                      GPU core is bad
                      Case closed
                        Originally posted by ss45 View Post
                        GPU core is bad
                        Case closed
                        Can I ask something?
                        How did you find out?
