good morning, Sony dont like to make life easy,why feed backlights via 2 or 4 wires when you can use 60!
yes there are 4 foils feeding 4 separate b/l edge strips via lcd drive board (the blue one in corner)
first ,after usual checks ,i unplugged cn02 at top of t con board
to stop the 4 blinks ,this allows main board to start and led remains green and sound comes up ,
next i fitted link to led-on from 3.3v sby ,removed lead from plug from main board just in case and tried again ,still no b/l .
while tv is still on i replugged cn02 and pic info is visible with test lamp ,
ie still no b/l but pic and sound info good .
so i think the tcon can be ruled out ?
the psu with the forced led on link produces 24v for b/l and all other supplies good .
now over to led drive board
there are 4 fuses all good
all diodes and fets test good
all caps good esr
theres a 3.3v supply and a 9v supply both good .
next i opened up and checked all 4 led strips both with led tester and with d/m od diode test mode both directions to check reverse zener
all tested good .
ive read a couple of posts on here with similar models,but not quite same volts from psu
i think my psu is good as it produces all correct volts when forced on with 3.3v
ive now reached the head scratching stage ,any ideas please
all caps good esr
all tested good .
