Need help with 4700uf 25v replacement in subwoofer
    Bought a cheap sub on marketplace for $20. Has two 4700uf 25v Jun Fu 85c rated caps. I've found several replacements for around $1 or 2 but what ripple current rating should I shoot for minimum? Also they have to be 16mm wide and a max of 30mm tall, lead spacing is 7.5mm and they are through hole.
    I am about to buy these just because they're cheap and 105c rated
    https://www.arrow.com/en/products/47...er-electronics
    Edit: add some bad 22uf 25v Jun Fu's to the list as well
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
    Re: Need help with 4700uf 25v replacement in subwoofer
    i wouldnt bother,
    your not hitting the caps with high frequency's
    if you do replace them you need high ripple current handling.
