Help me! XFX DD R9 280X
    Hello. Ic Q19 is missing on my video card. Can you say the name of the part of Q19 ic?
    Re: Help me! XFX DD R9 280X
    i might be wrong but that chip probably (more than sure ) has to be the Vbios chip of the card
      Since it is listed as Q19 I suspect it could be a mosfet, check if any of the pads are connected together. If it was an IC it would likely be listed with a "U" like U300 above it
        Hello. Thank you, I solved the problem and you answered correctly. Double mosfet connected to the U702 (APW7165C) controller.
          Good to here it is repaired, and thanks for the follow up.
            But I have another problem. The U900 (uP1509P) supply voltage is not output. Mosfets are solid, but I can't test the U900 without datasheets!
              I did some checking and the uP6122 seems to be the same pinout. Also this manual has a uP1509, PU9 on Page 90
                Thank you my friend. I will check it as soon as possible. I'm happy
                  I couldn't run it and I need help.
