Another Antec PS PP-303X 300W
    Yes another antec PS with Fuhjyyu CAPS..
    mine was weird... I had 2 boards act weird...
    1st one the atx power connector had 1 pin with a burn mark.
    2nd board one day my pc rebooted and it would not startup any more...
    so I tested the cpu 1st it worked, then I placed it back in the same board nothing..
    so I tried another Power supply bingo it works...
    BTW the Antec power supply still works... going to replace the caps latter..
    Wanna wait a few days to discharge the caps...
    here's some pics...
    Re: Another Antec PS PP-303X 300W
    The big caps will discharge in a couple of seconds on most ATX PSUs. First check the voltage between the metal case and the heatsinks - there should be none. Then remove the PCB (carefully to not touch the bottom side) and measure voltage across the big caps - if there's none, it's safe.
      Rainbow thanks for the advice on using a voltmeter..
      that make me more comfortable against getting a shock..
      anyway I recap all the caps except the 2 big ones...
      PS is running as I type...
