testing dual N-channel P-Channel mosfet in a 8-SOIC package
    I would like to know how to test in circuit dual N-channel P-Channel mosfet in a 8-SOIC package
    Thanks for your help
    Re: testing dual N-channel P-Channel mosfet in a 8-SOIC package
    Get the spec sheet so you can locate the S (Source), D (Drain), and G (Gate) pins.
    You use Ohm mode to check for leakage/short between the 3 pins combination, but most common failure mode in these MOSFETs are due to shorts/low reistance reading between S and D.
      What would be normal reading for pin D1 & S1 19.60 ohm
      D2 & S2 18.32ohm
        Below 30 ohms is possibly bad (short) if on the board. You would need to remove it to test further
          thanks selldoor
            I agree with selldoor.
              Thank you both for great information. By any chance would you guys know where I
              can buy P2804HVG and STM4953 dual N-channel P-Channel mosfet in a 8-SOIC package
              other then China or Hong Kong.
                Perhaps look at the datasheets for each then look for a substitute
                This might do for the 4953
                http://www.digikey.com/product-detai...4-1-ND/3050790
                  Thank you again selldoor
