Got this faulty Apple Cinema display 23" power supply for a few bucks and can't seem to find the main problem with it; hell, am still in the learning phase!
It's a SMPS with 100-240v, 50/60Hz input and 24,5v 6,1A (150w) output.
I found a shorted mosfet on the secundary site, the PSMN015.
Nothing else seems out of the ordinary by look and smell.
What I've done so far:
- Changed the shorted mosfet for a similar one --> no change.
- Checked the main fuse --> still good.
- Checked the main rectifier --> still good.
- Checked the voltage on the main filter cap --> 320v.
- Desoldered and checked the two 11N60C3 mosfets on the primary site for shorts --> still good.
- Checked the voltage on the primary transformer pins --> 320v on 3/5 pins.
- Checked all the primary diodes --> still good.
- Checked the two optocouplers --> still good.
- Desoldered and checked all electrolytics for capacitance and ESR --> still good.
- Changed two small startup electrolytics --> no change in Vcc voltage to the TEA1552t IC.
The primary has two mosfet driver IC's, the 14 pin TEA1552t and the 8 pin L6561D.
The secundary only has the 8 pin N4300 op-amp / voltage regulator.
The TEA1552t has 7.5v on the Vcc pin 8 (too low, has to be at least 11v), 320v on the DRAIN pin 7 and a very fluctuating 0-5v on 5v Vcc output pin 11 (obviously hangs in some kind of startup loop).
The L6561D has no voltages present on any of the pins.
The N4300 op-amp / voltage regulator also has no voltages present on any of the pins, because the whole secundary circuit is not getting any voltage.
My suspicion is that the TEA1552t IC is malfunctioning, hence the low Vcc input of 7.5v. As I understand from the datasheet, especially the block diagram and the text just beneath it, the IC is self sustaining and draws his Vcc from the mains on the DRAIN pin 7; this voltage is internally lowered to the correct voltage by the means of an internal cap (just suspect this, don't know for sure). I'm awaiting a new IC I've ordered to replace it.
I can't understand why only the mosfet on the secundary site has shorted out and not the mosfets on the primary site; I would guess these guys will catch the first blows, or am I wrong?
If anyone have any more ideas / suggestions what to check, I'll be happy to hear.
If better pictures are needed, I'll be happy to post them!
Some pictures:
Some pictures:
