Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate.
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook.
New layout for DM311 add on pc board. Features "McIverish" heat sink cut from tin can using tin cutter. Photos attached showing pc board attached to main heat sink.
Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
On my boards, I have never put a heavy load on the 5vsb, so the DM311 has never been too hot for me to touch. The "tin can" heat sink was just an add on idea for future loading. I might mention ......... don't touch that heat sink while the power supply is running. It has the switching signal on it between the +320 volt source and the FET switcher, an AC signal of something like about 600 volts peak to peak. Notice also that the added heat sink does not touch the other heat sink (which is tied to AC common on this model Bestec).
On Bestec ATX-250 12E #2 I have completed the recap process. The first 12E had mostly JPCE-TUR capacitors. This one had mainly Jamicons. So here is an analysis of how the Jamicons held up.
The two mains were CapXon 470 uF/200 volts. I had a burned board with a pair of Panasonic 560 uF/200 volt capacitors so changed the CapXon for the better Panasonic.
The "critical" capacitor:
C1 Jamicon 10 uF/50V >99 (not bulging) -> not used in DM311 mod
C50 CapXon 220 uF/25V .92 -> Nichicon PW 220 uF/50V .05
Note that C50 at 25 volt rating was changed to 50 volt rating. It normally runs at 20-22 volts. If 5vsb goes up, the voltage across C50 goes up proportionatly. Not much room for overload - one of the reasons this model had high failure rate.
The esr readings of the JPCE-TUR capacitors on the first Bestec were much lower (see earlier post in this thread) than the Jamicon capacitors. The Nichicon PW had nice low readings.
Before putting it back in the box, here are some photos of this Bestec with mod and recapped.
Here it is, back in the box. It has been recapped. It has the DM311 5vsb mod. It has the added fan which runs when the computer is turned off. The fan acts as a load resistance instead of resistor R102 which does nothing but generate heat.
The Bestec ATX-250-12E is the only psu I know of that has this circuit feature. When the computer is turned off, a transistor switches power from the pwm chip to a 1000 ohm resistor. It serves only as a heat generating load. So I remove the resistor (R102) and wire a fan in its place.
So go find you a Bestec ATX-250 12E and you can do some cool experiments!
I had the same problem with Seventeam ST-300BLV, +5VSB raise to 9V! because of 10uF/50V CapXon KM.
after I replaced it, +5VSB is back to normal.
Thank you.
My project was a bad Bestec power supply with blown 5VSB. I will now attempt to show photos and my hand drawn schematics.
I have also a problem with my bestec ATX-250-12Z rev C power supply.
The green component near the C40 (0,10uF/250V X2) is blown. I want to replase it, but does not know what kind of thing it is. The draw on the pc board is a resistor. But the discription is NTH8.
As indicated in above posts, it is a thermistor used as an inrush current limiter. You can probably use one from another power supply, Before replacing, I would check resistance on bridge diodes and switching transistor. A short in either place can cause your problem.
check the psu first, they wont blow unless something is shorted.
Not true. I've seen them fail and the PSU is fine after replacement. Especially true if the fuse is good. Most likely they blew because of they were underrated. Someone else had one do the same and posted in here awhile ago... momaka?
