LG 34UM95 - 34UM-P - Board is LM94Q/34UM95/EAX65360306 (1.0)
    Hello, i need bios for lg 34um95 monitor, having this monitor to fix 2nd time, i need bios dump for him. Already read the original one, saved it, cleared the chip, flashed again and it was working for few days. Now once again he's not turning on. Attaching dump what i got.
    Re: LG 34um95
    The EEPROM chip might ne bad and not holding the information very well and self erasing.
      Re: LG 34um95
      here a working dump for this monitor, in case someone else has this problem.
      It fixed it for me.
      Cheers!
        Re: LG 34um95
        It fixed it for me.
        Cheers!
        You saved me a lot of searching. Thanks for posting this here.
          Re: LG 34um95
          Just wanted to say, that I re-flashed the chip on my monitor with the backup I downloaded from here and my monitor now powers on again.
            Re: LG 34um95
            @REpairAT thanks for the file, worked for me on my LG 34UM95C (I got a kick out of German being the default language).
            Most of the repair info out there is for the 31MU97, where the IC205 chip is on the reverse side of the circuit board from the power plug. On the 34UM95C, it is visible as soon as you remove the back cover, on the upper-right hand side of the board.
              Re: LG 34um95
              Thank you very much for the bios.
              My board is LM94Q/34UM95C/EAX65360307 (1.1) and has the IC906 on short circuit.
              On it is written 3410I TI 51K D2KH G4.
              I can't find anywhere information about this chip or where I can buy it.
              Please if someone can help me.
              Many thanks in advance.
                Re: LG 34um95
                IC906 - TUSB3410RHBR - Texas Instruments USB Interface
                  Re: LG 34um95
                  Yes thank you very much!
                  I also find out that is an usb controller chip and I just took it out and the monitor works now.
                  I don't really need the USB on this monitor.
                    Re: LG 34um95
                    Hello guys, I cant start a topic yet so I want to try it here. Maybe someone else needs it as well.
                    I bought a 34UM95-P. With the same EAX65360307. Someone already played around with a repair and they did not fix it. IC102 was shorted on pin 6 and 7. And they knocked of a capacitor CB11/C811.
                    I flashed the bios back and now the screen does give a sign of life. The power led turns on for 10 seconds and turns back off.
                    IC102 was short so I assume that the controller is damaged or the file on it is corrupted. Can someone send me a copy of the rom on that chip? And can someone tell me what the capacitor is on CB11.
                    Thanks in advance!
                      Re: LG 34um95
                      Is not IC 902 actually ? You write IC 102 ? If yes I have the file, I will give you.
                      And for capacitor if is a small ceramic smd I guess you can put any, it will work.
                        Re: LG 34um95
                        Yes its IC 102. I dont know why they touched it when they tried a repair but I am guessing they thought it was the reason the monitor would not turn on.
                        It's the one really close by the green audio jack.
                          Re: LG 34um95
                          Hi there, I'm new to the forum, I'm here to try and fix my 34UM-P.
                          Once in a while it would just "crash" half the screen would go black, 2nd half would show scrambled image. Usually a power cycle would fix the issue, then once it did not..
                          I've tried to find a board to buy/replace, but I don't see any available.
                          I have the LM94Q/34UM95/EAX65360306 (1.0)
                          I didn't know I could try and reflashing the board to fixing the boot up issue.
                          Is there a tutorial somewhere that shows how one can try to flash the chipset with the originally attached bin?
                          This is the board.
                            Re: LG 34um95
                            You need a programmer like Chinese CH314A and software (look for CH341A Programmer), the chip should be the MX25L8006E.
                              Re: LG 34um95
                              Hi there, new user here!
                              Just wanted to say that I also got my monitor working by flashing ROM file posted here!
                              I downloaded the file, hooked up CH341a directly on to the chip on the board without desoldering it, flashed, and it is working now!
                              Thanks!
                                Re: LG 34um95
                                This is the board.
                                If you get half screen scrambled You might have to reflow the processor under the radiator that send signals to that part of the screen, this doesn't seems to be a firmware issue.
                                  Re: LG 34um95
                                  Big thanks for IC205 dump. I have been repaired two Lg34um-p and one Lg34UM-c-p. Thanks for help, im sending IC 102 dump, Tostieapperaatask ask for it.
                                  Cheers!
                                    Re: LG 34um95
                                    Cheers!
                                    You solve it with my dump for IC 102 ?
                                      Re: LG 34um95
                                      I fix it with dump from from REpairAT. O have one more from here https://www.elektroda.pl/rtvforum/topic3769527.html
                                        Re: LG 34um95
                                        Does anybody have a clue what could be the problem, left and right side of the monitor sometimes are not syncronised, and it is only noticed on moving picture. I 've repaired this monitor with flash dump couple months ago, and it works, but sometimes i get asyncronised left and right side.
                                        Video at youtube I uploaded in slow motion: https://www.youtube.com/watch?v=fgUwzhhSpKQ
                                        Do I need to reflash it again, or need to reflow the chips?
