Samsung Syncmaster 245b BN44-00195A
    Re: Samsung Syncmaster 245b BN44-00195A
    Opening J808 was only to remove the vcc from the main power supply ic, you can resolder it if you like. Yes dp803 is in the gate drive circuit for the pfc mosfet. so it is ok, so it could be that the pfc drive ic is bad? if it has all the correct voltages and it is not outputting a drive signal for the pfc mosfet, it could be that the ic is bad.
      Originally posted by Mandor View Post
      I took most of the electrolytic caps out and measured them and they all seemed fine on capacity test. Should i test in another way?
      I had some trouble with a Syncmaster 245T - BN44-00181A. I ended by changing all the Samsung caps. So yes, I recommend you an ESR-meter.
