Linkworld 200W AT PSU with Fuhjyyu caps
  • Rainbow
    • Aug 2005
    • 1371
    I've got a 1994 Linkworld 200W AT PSU. All caps are Fuhjyyu except the two big ones which are CapXon. They're all OK, the fan is OK too. I've only cleaned the dust from inside and it runs fine like new
  • Newbie2
    • Sep 2005
    • 885
    Re: Linkworld 200W AT PSU with Fuhjyyu caps
    I'm sure in 1994 the cap problem didn't exist until 5 or 6 years later.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • linuxguru
      • Apr 2005
      • 1564
      If the CapXon are 220uF/200v, then it's likely that the specs are over-rated on the SMPS - it's probably a 135W/165W claiming to be a 200W. Almost every commodity 200W AT SMPS in that era used basically the same topology - a half-bridge push-pull forward converter with self-starting primary, a TL494 (with an LM339 or a few transistors for the protection circuits) on the secondary side for regulation, driving the primary side through a small transformer that is also part of the self-oscillation circuit of the primary.
      Devilishly ingenious, and also the lowest-cost circuit topology for that power level (135W to 200W). The only problem is that many manufacturers skimped out and used smaller parts, but left the specs unchanged at 200W. Some of these will be missing the input filter circuitry, the high-voltage varistors across the primary capacitors, various output inductors, etc. They'll also have ridiculously small capacitors (1000uF) on the secondary, with some capacitors omitted.
      Try loading up your system with a few drives, and watch the +5v drop to +4.3v and the +12v drop to +11v. I usually replace the 1000/10v on the +5v with a 2200/10v, and the 470/16 on the +12v with a 1000/16v. This doesn't improve the rating of the SMPS - if it's overloaded, it remains overloaded - but it does improve the transient response and helps reduce the random reboots and shutdowns that sometimes occurred when a drive motor started spinning up and so on.
      It also helps to put 250v MOVs across each of the primary capacitors if there are unpopulated locations for the MOVs (usually marked ZNR1 & ZNR2). It improves reliability in places with noisy/spiky mains.
      • PeteS in CA
        • Aug 2005
        • 3578
        • USA, Unsure of Planet
        That puppy could easily have 40,000 or 50,000 hours on it. Those O/P caps could be at wear-out, and I'd watch that fan like a hawk. If the I/P caps are 220uF, 200V changing those to 330uF or 470uF (probably in the same or smaller case size) would help with the wimp factor, though the switch device and O/P rectifier heatsinks are another thing frequently skimped on and not easily improved.
        PeteS in CA
          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
          by momaka
          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
          https://www.badcaps.net/filedata/fetch?id=3591771
          https://www.badcaps.net/filedata/fetch?id=3591772
          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
          https://www.badcaps.net/filedata/fetch?id=359177...
          03-12-2025, 03:42 PM
        • eryjus
          Heathkit IO-4205 Power Supply Caps
          by eryjus
          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
          05-10-2023, 11:21 AM
        • Paxman_Swede
          Identifying caps on an old Zoom 9000
          by Paxman_Swede
          Hello!
          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
          I have studied the board and...
          01-14-2025, 09:51 AM
        • captain150
          Help with switching power supply caps
          by captain150
          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
