Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 02-25-2011, 08:14 AM   #1
Shodan486
Exclamation Understanding bus values
Hi all!
This time I won't be burdening you with questions of experience and so, but pure theory is on on the hand right now.
I have difficulties understanding the bandwidth speed of FSB and HT, Wikipedia is cloudy too, so that I want to point out (and be verified) certain things.
I'm worried about the real speed, meaning MegaTransfers per Second (MT/s). By my knowledge, I say FSB (as in PIII) is calculated like this, for instance:
FSB of 100MHz x 1 x 8 = 800MB/s
Where 100MHz is the clock of the bus, 1 is the cycle length (I guess it may be compared to burst mode in DRAM technologies), 8 is the 8bytes of a 64bit width of the bus. This is clear to me, let's move on with the core2 extreme:
FSB of 400MHz x 4 x 8 = 12800MB/s
The very same as above, only increased values. Now let's move to the problem. Problem with HyperTransport 1.0 (1.1) to be specific.
FSB of 200MHz x 4 x 2 = 1600MB/s
Yes I know all of the FSB should be base clock or BCLK, but here's the thing: 200 is the clock, 4 is the HT1.0 multiplier and 2 is the DDR ability of the HT. I'm using MBs deliberately as the market does (with AMD it did so) instead of MT/s, because right now I'm confused - where in that pattern is the bus bit-width value? Since the hypertransport has a 16bit connections, I should add one more ''x 2'' to it, thus getting the correct values, no?
Then it would be total fo 3200MB/s (or MT/s). Then why the advetisemens always shows 1600MTs or 2000MTs if the HT multiplier is 5, not 4000MTs?
Need to know if I'm correct, also just wondering if these results (3200 & 4000) are uni-directional or bi-directional.
Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
Shodan486 is offline   Reply With Quote
Old 03-08-2011, 06:06 PM   #2
Philly Cheese Steak
Philly Cheese Steak's Avatar
City & State: NEW YORK OR TAXLAND
Line Voltage: 120VAC
I'm a: Hobbyist Tech
Default Re: Understanding bus values
HT will change its speed at its own pace hence your not able to know the "set speed".
linkhttp://en.wikipedia.org/wiki/HyperTransport
and quote
HyperTransport also facilitates power management as it is compliant with the Advanced Configuration and Power Interface specification. This means that changes in processor sleep states (C states) can signal changes in device states (D states), e.g. powering off disks when the CPU goes to sleep. HyperTransport 3.0 added further capabilities to allow a centralized power management controller to implement power management policies.
SB-E 3930K
Asus X79-Deluxe
Asus 2X GTX 780 Ti DCII
Gskill 16GBRip [email protected]
Intel 520'S Raid 0
Corsair AX1200
Philly Cheese Steak is offline   Reply With Quote
Old 03-09-2011, 12:40 AM   #3
toygreen88
thank you for sharing.
toygreen88 is offline   Reply With Quote
Old 03-09-2011, 05:46 AM   #4
Uranium-235
Muffins
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
why are we trying to apply hypertransport to core2? I think HT is only on AMD's side till the later core-ix series chips
or are we? wait, your question seems somewhat confusing
Uranium-235 is offline   Reply With Quote
Old 03-09-2011, 07:08 AM   #5
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
^indeed
intel's "quad pumped" marketing crap is another factor btw..
CPUs with "800MHz" FSB are actually running on 200 "real" MHz.
- 400FSB -> 100MHz
- 533FSB -> 133MHz
- 800FSB -> 200MHz (kinda makes me wonder why there's no 166MHz/667FSB Oo)
- 1066FSB -> 266MHz
- 1333FSB -> 333MHz
- 1600FSB -> 400MHz
^this stuff started with the Pentium 4 and kinda ended with the Core 2 CPUs
Scenic is offline   Reply With Quote
