I have here several SCSI drives. I like to connect them to a PC. What is required in the way of connectors to IDE or SATA?
SCSI drives
Re: SCSI drives
You will need an Adaptec 29160 or 39160 card (fits in PCI slot on your mobo) and a 68-pin SCSI cable with terminator .
If the SCSI drives come from a later model server, they are probably 80-pin SCA, and you will need an adapter to convert the 80-in to 68-pin. ( 80-pin drives hot-plug directly to a backplane without a cable)
I do this all the time as I have a large number of SCSI drives on hand.
If the SCSI drives you have are 50-pin forget it. Also if the drive has "FC" on it, it's Fibre Channel. Forget that too.
SCSI drives are fast, especially the 15K rpm ones.
Re: SCSI drives
There's also more to SCSI than setting Master or Slave - you have to jumper each drive to a unique address (from 0 to 15 for 68-pin SCSI, with 7 usually allocated to the SCSI controller itself)
If the SCSI cable does not have a terminator on its end, make sure only the final device on each SCSI connection has Termination set On - all other devices must be Off
Instead of Adaptec controllers, I prefer LSI, previously called Symbios, originally called NCR
However, Adaptec documentation is perhaps more SCSI newbie friendlybetter to keep quiet and be thought a fool, than to open your mouth and remove all doubt
Re: SCSI drives
I agree 4.3GB is too small to be useful. It takes 3GB or so to load an operating system. If it is a 68-pin drive you could chain several together on the cable, but even still, too small.
Show us the end where the cable connects. Also does it say on the Drive what the speed is? Some are 7200, some are 10,000 and some are 15,000 RPM. 7200 is not desirable.
If it's an 80-pin SCA drive you have to use an adapter, and are recommended to have no more than 2 drives per cable.
Also the older drives can run hot and be whiny.
Remember these things run 24/7 for up to 7 years.
The Mean Time Between Failures (MTBF) of SCSI is 1.5 million hours (yes).
That's why they cost more and that's why they are kept in service so long.
At the end of their lives they can be "tired".
Compaq does not build their own drives, that one looks like a Seagate or Fujitsu. I prefer Fujitsu - cooler and quieter. Maxtor and IBM (later Hitachi)
also made SCSI drives.
Re: SCSI drives
4.3, 10k (10000 rpm)
maybe with a HBA using linux raid 5 you can get some decent space if you put like 7 of these in, but that decent space is sill very small (25G for 7/w raid 5)Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: SCSI drives
Think of all the power they consume too. Even the 36gb drives are too small. I'd wait till you get some 73gbs. They are very common.
Get a cheap jbod (hp disk system, etc) and a scsi card. These drives are very loud so even for free they might not be a good idea when a 1TB ide drive is < $70.
I have a box of FC drives of a decent size but I can't really do much with them as everything to do with them is expensive. Can't sell them because they came out of customer's servers and probably have data on them.
Re: SCSI drives
it would be cheaper just to get two 320gb sata's in linux software raid 1Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: SCSI drives
Make sure that you use the right SCSI terminator (SE or LVD).
Serial Attached SCSI (SAS) dispenses with terminators.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
Re: SCSI drives
Originally posted by kiddznet View PostI have here several SCSI drives. I like to connect them to a PC. What is required in the way of connectors to IDE or SATA?
Considering they were free its crazy to say it would be cheaper to buy the other drives (SAS) etc the others mention. Speed wise and $ wise they are plenty fast enough setup as I suggested and your investment will be much less than all the other suggestions.
Re: SCSI drives
Originally posted by dood View PostYou're not going to find anything to convert them to IDE or SATA. As seanc said, pick up a PCI SCSI card.
Or, if they're older drives, toss 'em. SATA is faster than the old clunker SCSI drives anyway.
Older 10K SCSI are still faster than 90% of the SATA drives now made (just because its a Sata drive doesn't mean its doing 1.5g or 3g transfers) the older SCSI drives spinning at 10k RPM and small like these 4.6G drives are screaming fast in a raid and will own most any SATA drives in benchmarks on the proper controller.
In fact 2 of these small 10k SCSI drives in raid 0 on a 39320 controller bench faster than 2 WD Sata 10k raptors, I know this for a fact as I have both setups.
Re: SCSI drives
Well I rummaged through the stuff I got with the server drives and I have an Adaptec SCSI PCI card 19160/29160 N but I am ,still none the wiser what I need in cables
939 DualCore AMD Opteron, 1800 MHz (9 x 200)
Abit AN8 / Fatal1ty AN8 SLI Series
3072 MB (PC3200 DDR SDRAM)
ATI Radeon HD 4300/4500 Series (1024 MB
Lian LI Aluminium mesh case
