I recently was given a broken ViewSonic flat panel monitor. Specifically a ViewSonic Optiquest Q191wb, model number VS11584. It's a 19" widescreen LCD monitor with CCFL backlighting. The reported problem was the monitor would not turn on.
Step 1 was to open the monitor up. This ended up being more difficult than I had expected. Like so many monitors of this size it's held together by plastic tabs around the edge. But these tabs were very difficult to pop open. I ended up making a few minor scratches in the plastic as I pried it apart.
Once open the monitor looks like every other monitor, the video board is on the right and the power/inverter board is on the left underneath some metal shielding. After I removed the shielding I immediately noticed a bulging capacitor. I ended up replacing the following 4 capacitors:
C802 470uF/50V
C817 1000uF/16V (obvious bulge on top)
C819 680uF/16V
C904 220uF/50V
After acquiring the replacement caps I began the repair. I removed each capacitor, soldered in the replacement, and then tested the old capacitors using my multimeter. I know, I should probably test them first that way I don't replace good caps, but I figure caps are cheap and I'd rather not have to repair this monitor a second time. So I just went ahead and replaced all four. Unfortunately, my capacitor tester cannot handle electrolytic capacitors above about 500uF, so I could only test two of the capacitors. Here's what I found:
Location | Rating | Measured Capacitance | Comments
C802 | 470uF/50V | 433uF | Probably bad, 433 is only 92% the rated value
C817 | 1000uF16V | na | Unable to test, but was bulging
C819 | 680uF16V | na | Unable to test, probably was still good
C904 | 220uF50V | 219 | Most likely still good
I used the following replacement parts from Digikey (part numbers are Digikey part numbers):
Panasonic EB series 470uF/50V - P13134-ND
Panasonic EB series 1000uF/16V - P13119-ND
Panasonic FR series 680uF/16V - P14395-ND
Panasonic EB series 220uF/50V - P13131-ND
Digikey is great. Parts were $2.86 plus a couple of bucks for standard USPS delivery. Parts arrived in 2 days.
After soldering in the new caps the monitor works perfectly! So for less than $5 and about 5 minutes of actual work time I have a working widescreen monitor. Thanks to all the members on this forum. Everything I've learned reading other posts helped this repair to go smoothly.
Hopefully this post will help others who might be experiencing problems with their Q191wb monitor.
C802 470uF/50V
C819 680uF/16V
C904 220uF/50V
