You solder the wrong SPI BIOS chip on the wrong board...... then press go..
what happens say if....
Re: what happens say if....
As long as its the same chip, probably nothing. it shouldn't go up in smoke unless you put it in backward or something....but if the POST config on the eprom doesn't match the motherboard, it simply just won't POST.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
If they are SPI they probably support in-circuit programming.
My MSI 790GX-G65 even provides an ICSP header but you may be able to get away with just tacking or clipping some wires to the appropriate pins..."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn
