Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 06-21-2014, 03:47 PM   #1
JonathanAnon
City & State: Kildare
My Country: Ireland
Default What else have you guys been fixing !
I've fixed TVs and laptop PSUs (and similar power adapters) mostly since I started learning how to fix power supplies... Oh, and I did fix a treadmill as well .. They cant take that away from me... :-)
But what else have you guys been fixing. I buy stuff from those ebay type websites and fix them, so I'm looking for other opportunities for fixing and hopefully earning a few quid...
JonathanAnon is offline   Reply With Quote
Old 06-21-2014, 09:41 PM   #2
goontron
5000!
goontron's Avatar
City & State: South Greeley, Wyoming
My Country: US
Line Voltage: 13.9kv HT service and some 240v center tap oddity.
Default Re: What else have you guys been fixing !
well in Colorado growing pot is legal and they tend to use those shitty inverter based ballasts that nuke the AM band, those are what i fix.
its usually a bad cap, or a burnt resistor in the startup circuit. all caused by pot tar getting in the bearings, which let me tell yah pot tar mixed with motor oil looks nasty!
Tomorrow Is Nearly Yesterday And Everyday Is Stupid!
goontron is offline   Reply With Quote
Old 08-06-2014, 05:21 AM   #3
Mr.Orange
City & State: Cork
My Country: Ireland
I'm a: Hardcore Geek
Sometimes fault-find car wiring and car electronics, sensors, but not into mechanics. Proper wiring of car trailers with LED lights (solder joints with heat shrink, no connectors unless in water sealed junction box, electrical conduit secures & protects wiring)
I repaired a frost-free Samsung Fridge/Freezer there's a thermal fuse inside near heating element which switches on periodically to remove frost from cooling element, after a time these will go, a limited usage lifespan in such temperature variance , took a while to learn n' figure out. I kept the fridge as didn't want the responsibility if something went wrong after as couldn't get correct 85C part local so went for higher value.
If electrons flow through it, it's pretty much the same thing, input control output.
A simple cheap SMD airflow tool is a handheld gas soldering iron without the iron :. is a selective hot airflow which can be regulated by turning up/down gas, also no onerous air lead. I have replaced many components without damaging them or the solder pads all within seconds... can also be used as a soldering iron & on heat shrink
Mr.Orange is offline   Reply With Quote
Old 08-06-2014, 11:06 AM   #4
diif
City & State: Midlands
My Country: England
My friend has a mobilty scooter that died. The company that sold it told him it needed a new motor costing 400. Either they are thieves or inept. Turned out to be the manual/electrical brake on the end that was at fault. 50 for a second hand one.
diif is offline   Reply With Quote
Old 08-06-2014, 11:21 AM   #5
SteveNielsen
Retired Tech
City & State: Newport, OR
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
I'm looking at an old Tripp Lite line conditioner, model LC-1200. It works but regulates to 110v, not 120v. I can find no information about it. Pic of transformer attached. Obviously needs cleaning.
SteveNielsen is offline   Reply With Quote
Old 08-06-2014, 12:00 PM   #6
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
Well,today I fixed a old speaker that was broken using what I had.
The result?It works,but it's real quiet,since the new one was built from 3 small speakers wired together (kinda like laptop speakers) and it sounds like a laptop speaker.
Other than that,nothing to complain about,it sounds nice. However,I still have to add 3-4 more small speakers like that so it at least would sound as loud as the other speaker. (the right speaker works,it was the left that didn't work)
A pic of how the speaker looks (pic not mine anddon't mind the PCB and the switch in the pic since I don't use them,just the speaker) :
Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Dan81 is offline   Reply With Quote
Old 08-06-2014, 01:08 PM   #7
Mr.Orange
City & State: Cork
My Country: Ireland
A friend asked me to have a look at one of those he had replaced the key barrel as OAP lost key, after couldn't get it to go and no patience wrt electrics. I went there just to get the manual to read overnight, as never seen one before no idea what to expect, turns out just had to turn on key then press a button like an ignition button for it to work, thankfully as I didn't feel like playing with motors.
There was a scam in the UK with mobility scooters think was on "don't get done/scammed with Dom"
Old 08-06-2014, 02:56 PM   #8
diif
My Country: England
The engine and gearbox came out in 10 minutes and I fed it 24v from my power supply. A short was indicated, upon closer inspection someone had bypassed the brake switch with some twist and tape ! With the solenoid removed the motor then ran. I re soldered the brake switch and when we turned on the scooter it gave us a beep code indicating the brake solenoid.
Old 08-06-2014, 03:27 PM   #9
whiz62
whiz62
City & State: sand springs, oklahoma
My Country: usa
Line Voltage: 120vac 60hz
fixed my mom's sprinkler system circuit board. would not program, display just flashed on and off. took board out and had bad cap! anyway replaced it and it started working. $1.69 vs $200 Got lucky again!
whiz62 is offline   Reply With Quote
Old 08-07-2014, 09:08 AM   #10
Shodan486
Wiring to the antenna, headphones, simple home stuff. Tried to recap a mobo of which I have no details, 4 caps (2 3300uf and 2 1000uf) were bulging, though showed not problems when in the mobo, after removal I got 3,4ohms and a broken circuit message from my PEAK ESR meter. Replaced with 2 brand new Rubycons and 2 spare noname whatevers - upon my turn on the Serial Port driver (i presume) and a VRM regulator exploded . As I mentioned - no info on the mobo, was just given to me, and after inspection I found the mobo being bent much on the bottom, which basically gives me a hint that the previous owner didn't care much about it. Also found some corrosion, thus didn't bother myself with that. Proceeding to a mobo with all the caps bulged for the CPU VRM, but the mobo still boots up and is stable, thus will tell me if I solder the stuff correctly or not - just a beginner you know - but it's pretty easy, just need to prove it to myself.
Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
Shodan486 is offline   Reply With Quote
Old 08-07-2014, 10:28 AM   #11
SteveNielsen
Retired Tech
I'm rebuilding an HP Pavilion 1102. Hot hard drive, bad sectors, root-kit infections, power supply shutting down. I've got stuff wanted (pics and vids) backed up to another drive safely, it is basically working after replacing the power supply and drive and installing a fresh OS.
I am dismangling an old Dell powered subwoofer for fun. Maybe see if it can be a general purpose amp or little guitar practice amp.
Old 08-11-2014, 01:26 PM   #12
JonathanAnon
My Country: Ireland
I use two options for backing up PCs where I work, Steve... Disk2VHD and Clonezilla.. Clonezilla is fantastic and will even backup up RAIDed SAS Server disks... BUT, it will only restore the image file back to a disk (meaning that you cant easily access the data without doing a full image back to another empty disk)... I had one of Pavilions in to the shop a few years back... GPU desolders itself... Dreadful stuff, shape on HP for that one.
Old 08-11-2014, 02:44 PM   #13
mmartell
City & State: Windsor ON
My Country: Canada
Samsung laser printer (bad cap), oscillating fan (dry bushing) and the magnifier head broke off its swing arm so I had to rig something up. May need more attention at a later date lol.
mmartell is offline   Reply With Quote
