Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 11-09-2015, 10:31 AM   #1
Shodan486
Default Cisco pix 506 fw psu
Hey there !
Been a while since I visited this lovely site ! Hope everything's alright, saw some red notification up there, hope the admin & badcaps store ain't in no trouble !!!
So I wanted to start my cisco trainings and stuff, hooked up my FW mentioned above to the PSU, worked one day. Did the same thing the next day, nothing. Dead. Tried the spare one - worked.
Disassembled, investigated. The PSU looks OK, no burnt spots or parts. Providing the picture. There is one indication of a failure, fortunately. The place with caps and the regulator is ''ticking'' (not like a bomb ), producing the sound twice per second. I think it is the regulator, but that's why I'm writing in here - to ask you guys if I'm right. Providing pictures.
Appreciate the help in advance !
Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
Shodan486 is offline   Reply With Quote
Old 11-09-2015, 12:26 PM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Cisco pix 506 fw psu
ticking is either a shorted output, or a bad startup capacitor.
change the small cap c4 next to the control chip
and check the diodes on the other side of the transformer
Old 11-10-2015, 09:06 AM   #3
Shodan486
Thanks for the advice !!
The diodes show 470 and 778 values on the diode test. The regulators (the ones attached to the heatsink) show values between 400 - 650 when you measure the leads, but one of them shows 600 on one leg and beeps (short) on the other leg - which to me (since I'm an total amateur) is not a good sound. But I believe that removing the parts and measuring them outside the circuit is more reliable, thus will remove them and measure.
Should I continue replacing the C4 cap if this has been discovered?
Old 11-10-2015, 09:55 AM   #4
stj
stj's Avatar
it will last longer if you do, even f it's not the problem.
make sure you use a low impedence one like a panasonic FC/M/R or a rubycon ZL for example
Old 11-10-2015, 02:13 PM   #5
Behemot
Behemot's Avatar
City & State: Prague, 504'52.22"N, 1423'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
What's the original cap?
Behemot is offline   Reply With Quote
Old 11-10-2015, 03:17 PM   #6
Shodan486
25V 47uf Rubycon, which should be one of the best. Looking for a spare one now...
Old 11-10-2015, 03:24 PM   #7
stj
stj's Avatar
what series of rubycon?
Old 11-10-2015, 03:36 PM   #8
Shodan486
''YXF'' , those should be low impendance @ 105C
Old 11-10-2015, 03:46 PM   #9
stj
stj's Avatar
yxf is entry level low, and it's obsolyte - think the lowest you can buy now is yxg
so it's pretty old.
Old 11-10-2015, 09:25 PM   #10
Behemot
Behemot's Avatar
My Country: CZ
But it's oil electrolyte if I am not mistaken so it should really work for ages. If you have a meter, try measuring it, if not, well than it's worth trying to replace it…
Old 11-10-2015, 10:03 PM   #11
stj
stj's Avatar
yxf are good performers - specially in audio gear.
but they do fail if they are near heatsinks, i'v seen a few go.
Old 11-12-2015, 08:52 AM   #12
Shodan486
Why would they fail near heatsinks? Anyways, still haven't found a replacement one, I'm gonna hit the electro shop we have in the town tomorrow.
Old 11-12-2015, 09:52 AM   #13
stj
stj's Avatar
capacitor lifespan is directly related to heat because the liquid in it can dry out or crystalise.
Old 11-12-2015, 09:58 AM   #14
Behemot
Behemot's Avatar
My Country: CZ
More like chemically react and create compounds which are solid, not liquid. Drying may be the case of water-based electrolytes, but it is not like there is water floating inside, it's chemically bonded too.
Old 11-12-2015, 10:39 AM   #15
Shodan486
Sure it's the heat that usually kills the caps, but I thought that it would be something else since you said you've seen a few go . Nevermind and thanks anyways stj, because Behemot here stated an interesting fact : " Create compounds which are solind, not liquid " . Behemot can you elaborate, please?
Meanwhile I'm gonna dig through my junk board to see if I can find that cap, motherboards have similar ones near the audio chip usually.
Old 11-12-2015, 10:43 AM   #16
stj
stj's Avatar
i doubt a motherboard would have low esr near the audio chip.
you can probably use 100uf if it's easier to find.
Old 12-04-2015, 02:54 PM   #17
Shodan486
Replacing the mentioned capacitor did no help. I've acquired all the other capacitors as well, I'll try to replace them all.
Old 12-04-2015, 04:33 PM   #18
goodpsusearch
City & State: Thessaloniki, Greece
My Country: Greece
Line Voltage: 230VAC 50Hz
Never seen a failed YXF in my life. If you ask me they are as reliable as caps can get.
goodpsusearch is offline   Reply With Quote
Old 12-04-2015, 05:08 PM   #19
Shodan486
Measured it outta circuit - no problems at all, a slightly increased impendance only.
Old 12-13-2015, 04:51 AM   #20
Behemot
Behemot's Avatar
My Country: CZ
Originally Posted by Shodan486 View Post
Sure it's the heat that usually kills the caps, but I thought that it would be something else since you said you've seen a few go . Nevermind and thanks anyways stj, because Behemot here stated an interesting fact : " Create compounds which are solind, not liquid " . Behemot can you elaborate, please? .
For example salts and other compounds. The electrolyte and the foils react and loose their function. Capacitance descreases, ESR increases.
