Software to analyze Video RAM faults on graphics cards?
This is a sticky topic.
    Re: Software to analyze Video RAM faults on graphics cards?
    Originally posted by dicky96 View Post
    If anyone is having problems with the 32GB 3.rar file then you can try download it from my google drive.
    I split it the third file into 4 parts of around 8Gb each. Just download all parts to the same folder then right click on 3.part1.rar and use WinRAR to unpack it and it will reconstruct the whole file
    Of course you need WinRAR installed to do this but it is free to download.
    1.rar
    https://drive.google.com/file/d/1eDV...ew?usp=sharing
    2.rar
    https://drive.google.com/file/d/1uEt...ew?usp=sharing
    3.part1.rar
    https://drive.google.com/file/d/1Ten...ew?usp=sharing
    3.part2.rar
    https://drive.google.com/file/d/1qTT...ew?usp=sharing
    3.part3.rar
    https://drive.google.com/file/d/1zy6...ew?usp=sharing
    3.part4.rar
    https://drive.google.com/file/d/1uOP...ew?usp=sharing
    Hello frend,
    Winrar is password protected, can anyone share information about the password?
      Could someone explain me installation in english?
        For some reason I can not download 3rd part.It stucks at around 4Gb.
          Can anyone share on some upload website 3rd part...for some reason I can't download more then 4 gigs of that part?
            Is it possible to create installation on USB pen drive rather then external HDD?
            I have 64 GB pen drive.
              Hi, does this software works with laptop GPUs? Or only PC?
                Same question. but i can use 128 or 256 GB??
                  Originally posted by FreedomOne View Post
                  That solved the error 13 invalid or unsupported executable format for me. Thanks
                  Hi, I have the same problem...downloaded the linked version but that one is i english...is that correct?
                    Thanks for the tips on how to install new vram test and also windows repair.
                    works nice but the new amd test like rx6800 do you use rx5700?
                    i only have rx 5000 series and radeon 7 there.
                    is this correct?
                    [QUOTE=Fasse-sweden;1160774]Hi, I have the same problem...downloaded the linked version but that one is i english...is that correct?[/QUOTE
                    I dont think the language matters if its the correct version of diskgenius
                      how to vram test amd rx6800xt or 6900xt models? i have 5 partition bootable test disk but cannot test at 6800-6900 selection? thanks
                        Thank you for the links!
                        I have two questions regarding MATS for which I couldn't find concrete answer to them elsewhere. Hopefully it's not OT here:
                        1. Is it possible to have a faulty chip (that for example always crashes the card upon driver install) even though MATS doesn't report any errors?
                        2. Can a faulty memory stop MATS from running altogether (empty report.txt)?
                        Thank you so much.
                          I ran this test in a failing 3070. It gave me 64 errors on both banks of channels A and C.
                          === MEMORY ERRORS BY SUBPARTITION ===
                          SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
                          FBIOA0 0 64 0
                          FBIOA1 0 64 0
                          FBIOB0 0 0 0
                          FBIOB1 0 0 0
                          FBIOC0 0 64 0
                          FBIOC1 0 64 0
                          FBIOD0 0 0 0
                          FBIOD1 0 0 0
                          Any ideas where to look for the problem? Could it be that all four banks went bad the same "mild" way? or should I be looking into something else such as power delivery, etc?
                            Originally posted by ktmmotocross View Post
                            guys is there a version that runs on UEFI system?. i need to diagnose laptop but there is no legacy mode option in bios
                            me too. I did not find it
                              guys have somebody newer version of lorg of gpu or simmilar utility to check memory errors on 6900XT and 6950XT gpu ?
                                Hi everyone,
                                I've got a problem with rx5700xt. Card is detected, drivers loaded, but when i use furmark to stress it, i've got artifacts.
                                I've tried ./tserver -boardtest=memfa, but no errors
                                so i/ve tried to increase clocks by using ./agt -mem=1000, but clocks are still 300MHz for engine and 875MHz for vram
                                Do you know, how can i ncrease clock to do vram tests at more stress condition?
                                  1.rar
                                  2.rar
                                  3.part1.rar
                                  3.part2.rar
                                  3.part3.rar
                                  3.part4.rar
                                  Hello Dicky96 , did u ever solved your problem ? Im running into exactly the same problem u have/had . Kind regards
                                    Or did anyone else find a solution for this ?
                                    "[firmware bug] TSC_DEADLINE disabled due to Errata: please update microcode to version 0x22 (or later)
                                    acpiphp_ibm: ibm_acpi_init: acpi_walk_namespace failed
                                    Booting TinyLinux 20.10
                                    Error: initrd version 20.10 does not match TinyLinux version 18.07"
                                    Thanks in advance !
                                      good video this will really help every new member
                                        hi Mats to RTX 4090?.
                                          yes for RTX4090 there is only where do you always get the latest version?
                                          https://www.youtube.com/watch?v=q_kWonOzoag
