Trying to fix for a friend of mine.
Random keys (primarily L, M, A, and G) occasionally duplicate inputs (you press the key and get 2 copies of the letter instead of one)
Googling led to a person saying the issue is the board flexes over time which makes a bad joint on the 0 Ohm resistors along the back of the board. So I opened the keyboard up and reflowed every single resistor. Every one I heated with hot air, nudged it and let surface tension pull it back in. I tested the resistors and they are all close to 0 Ohms (0.2 to 0.3 ish)
I also swapped out the L and M key with 2 keys that were never, ever used just to eliminate any mechanical failure.
Upon testing however, the keys still occasionally duplicate. It is working better, but still not perfect.
Any ideas?
Any ideas?
