Dell n5010 can be converted from graphic version to non graphic
    Re: Dell n5010 can be converted from graphic version to non graphic
    Back to this thread , after a success conversions i face this one : Only backlight no picture !
    try to resold all the components ans still the same ...any idea please
      remove 2 caps up r 1m
        Thank you ..i did this too before as suggested at post n 55..but still the same : only backlight no picture
          Hello; i to make conversion with succes; initialy, my laptop it's working properly, but when i load in windows, i get bsod, ati file crash. So, my mainboard was not dead 100%.
          After i make all changes from picture attached, at first power on, i get 5 beeps; after turn off and on again, all is working perfect(keyboard was not connected; i power on laptop with minimum of pieces) .
          Remember to get out battery bios before begin process.
          And, remember after soldering every pieces, to check with magnifier that solder is done properly.
          After reading all 8 pages, to lower some how temperature of chipset, i measure and cut black plastic film underneath keyboard and put a thermal pad with 1mm thickness, to move heat from chipset to keyboard chasis.
          Laptop has i3 first generation, and with 4 gb ram and a 120gb oem ssd, windows 8.1 is flying.
          I attached picture, and a archive with picture unresized.
          Thank you.
            I convert it discrete to uma but hdmi and vga port unable to work. External display does not detect. Intel graphic display driver is fine. What to do?
            help please
            Thanks in advance.
              The described conversion method is only for the internal screen. The external displays do not work. and it is normal.
                Is it possible to make display in externa monitor or not?
                Thank you for your response caspian.
                  It is probably possible. but you need to modify the mainboard more. It is not done by anyone yet. So you have to discover it yourself. I think it is not worth it to try, because it is possible to damage the mainboard.
                    Originally posted by vektro View Post
                    Hello friend,
                    recently i converted an N5010 board using Dr. Bios way.
                    It works only for laptop's display, not HDMI's or VGA's outputs.
                    Now i am trying to resolve this too.
                    Check the attachment.
                    I have Solved VGA Output issue.
                      Hello friend,
                      It works nice.
                        Originally posted by vickey_vip View Post
                        I successful do it on my motherboard which part no is following
                        09909-1
                        DG15
                        48.4HH01.011
                        DO THE FOLLOWING CHANGES WHICH I POSTING IN IMAGES
                        FOR THOSE WHO HAVE WHITE DISPLAY FOLLOW INSTRUCTION WHICH SHOWN IN PICTURE
                        if any one have issue msg me
                        Thanks, it works.
                        I think some heat dissipation method need for the PCH.
                          Originally posted by teknikbursa View Post
                          Thank you very much
                          Also on the second page of pdf there is a schema. is it possible to explain?
                          thanks
                            Hi all can i use this 25mhz crystal?
