So there's an old TV in the living room. The picture starts out fine for a few minutes then does what's in the pic. Sometimes it'll go back to working fine or stays like that until it's turned off. The sound works fine so I just use it for the music channels. Is it connection issue or something inside?
What would cause a TV to do this? (Old Sony)
Re: What would cause a TV to do this? (Old Sony)
If the fault is intermittent, check the connections on the vertical output ic and in the vertical output section.
This is a Sharp not a Sony
How about a model number? and when you take the back off, provide some pictures of the chassis.Last edited by R_J; 02-03-2021, 05:42 PM.
Originally posted by R_J View PostIf the fault is intermittent, check the connections on the vertical output ic and in the vertical output section.
The sticker fell off in the back with the model number and all that but from doing some research it appears to be 25j-s100. I'll take the back off and take the pics tomorrow.
I took it to my room and hooked it up to a different coaxial cable and it seemed to work when I moved the cable to a certain position but the tuner is fine. Dont think its the cable cause it works on the other TV.Last edited by CapsDude; 02-25-2021, 10:27 PM.
Originally posted by nomoresonys View PostIt's an old crt tv right? if it's not a simple fix, you can grab another, they give them away daily on craigslist, just always make sure the meeting place isn't a dark alley.
Originally posted by petehall347 View Posthave you checked recent prices of old crt tv.s and monitors ?Last edited by nomoresonys; 02-26-2021, 05:35 PM.
Originally posted by nomoresonys View PostHere in the U.S. they are FREE in perfect working order, might be a different story in your neck of the woods. I gave all mine away about 10 years ago.
