Sony KDL-48W605B no picture but sound
    hello guys,
    today I buy Sony KDL-48W605B for repair
    tv turn on ,backlight on but no picture, i click menu sound ok.
    I found little fuse on tcon?(see pic) blown. so I solder wire to check if it work,but not working
    what do you think?
    panel or ?
    Re: Sony KDL-48W605B no picture but sound
    Replace the T-CON Bd.
      this model have t-con glued on panel,so I cant remove it from panel.
        pics
          Safety has fired because it is a short or very high consumption. Look for a smd capacitor in short or a dc-dc converter with trouble.
            Yep, start checking for shorted cap/s on that integrated T-CON board, do not put wire in place of the fuse.
            Similar to this: https://www.badcaps.net/forum/showth...ONY+KDL-40W590
              ok I am checking now...
              Vin_12V : 12.75V
                great,now tv dont turn on ,just 5 red light blinks
                  ok guys ,I think I found something
                  I found 4 caps shorted to ground CD14,CD15,CD16,CD17
                  but what I see CD14 is cracked?
                    ok removed cap from board,and now no short on 3 caps to left
                    now I need to find specifications of cap I removed,I dont have capacitance meter
                    I have old mainboard from tv, and found same size of cap
                      I found old t con board from SONY KDL-42W705B ,I will desolder one capacitor same size and check if will turn on with picture.
                      or it is not good idea
                        The four capacitors are in parallel. It works with just 3. If not, there are other problems.
                          Ok, so what do you get with the one bad cap removed, any change??
                            tv turn on,no red light but still no picture..hmm
                            my mistake,I have tv on my bed so I dont see picture till I click menu
                              ok guys , I have picture without cap that is shorted.
                              tv is working fine,I will test him for few hours.
                              anybody know that cap values? or leave it like this?
                                CD14,CD15,CD16,CD17 are probably all the same value. If you have any way to measure capacitance, then you can remove one of the good capacitors and measure it's value.
                                  Leave that. It also works with 3 parallel capacitors. Do not ruin him worse.
                                    Well that's cool, good to know it will run fine one cap down.
                                      They put in 4 caps for reason, they would have put only three to save money if the fourth one is not needed.
                                        What do you think will happen if he doesn't replace the cap?
