Sony KDL-48W605B no picture but sound
    Re: Sony KDL-48W605B no picture but sound
    It depends on what circuit it is being used in, if it is in the power supply then it will have higher ripple when load tries to draw more current. Right now he may not see the artifact on the video but may be certain condition he may see the effect on the screen. If he can live with it and his eyes are not good enough to notice any thing on the screen then he can leave it.
    I am not sure if you are old enough to know about Muntz, read about his TV.
    http://www.madmanmuntzmovie.com/?m=2
    https://www.autodesk.com/products/ea.../madman-muntz/
    Exert:
    Then came the TV years. Muntz thought the television sets on the market at the time were far too complicated, so he experimented by buying an existing set, disassembling it, then removing parts one at a time. If the set still played, he removed another part. Then another and another. Finally, with the set simplified as much as it could be, it became a Muntz TV! And these black and white TV sets, the smallest of which sold for $99.95, breaking the $100 price barrier for the first time, became some of the hottest selling consumer products in America.
      I will put capacitor back,but I need to wait for capacity meter...
        First I heard of him, VERY smart guy, inventor and business man, interesting reading about his life.
          ok guys,I change capacitor ,and new fuse..Tv is running fine
          thank you all
            Thanks for the follow-up.
              thank you all
              yours TV early you reported it work fine with out cracked cap.
              https://www.badcaps.net/forum/showthread.php?t=77491
              good you noticed cracked cap. and all of those connected are do one job only discharging lcd pixel. in short you should after replace cap need to preform the set playing over flew item like live football to be sure there are smooth display-- this thought only with adjust measurement Gama camera will done not just human eyes. sorry to tell this for me non repair.
                The man said it's fixed, I'll take his word for it.
                  Each capacitor is 10 uF
                    Hi, I have the same issue, have sound but no picture,
                    Anyone have a picture of what I should be looking at
                      Read post #3 and on.
                        Have the same problem with this tv, measured the voltages and went through the chart in the service manual > states to replace faulty t-con.
                        Now the problem, how to replace the t-con board.
                        I would appreciate it if someone can tell me how on how to remove the bronze colored panel ribbon cable from the TCON board that seems to be connect at the other end to the panel, without destroying it. I hope to then fix the ribbon cables on the new TCON board.
                        The cables look like they have been glued on to the TCON board. I've attached some pictures to hosw the cables. Any help would be appreciated.
                          NO do not remove that, what they are referring to is a stand alone tcon board, what you have there is not and you are right, removing that will pretty much ruin the tv.
