Thread Tools | Display Modes |
#1 |
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
I'm a: Professional Tech
![]() Model-Dell Inspiron 3521
M/B-La-9104p rev 1.0(A00) Problem-Dead The ene kbc was shorted, so i replaced it with a new one and programmed it as well with Rt809F. unit still has no 3.3v I have tried the following: 01. Replaced another new kbc and programmed-still same 02. Replaced Pu200 with TPS 51125-still same 03.Replaced Pu100(ISL88731)-still same. 04. There is no short on 3v and 5v coils(PL200 & PL201) 05.Tried flashing both Eprom's-still same. I have noticed one thing which has left me puzzled--If i connect pin16 of Kbd Connector(which is connected to pin 42 of KBC) to Ground-all voltaged appears on the board-3.3v at battery terminals and power switch. Mb wont turn on simply coz connecting pin 42 of kbc to Gnd means KBC is in programming mode. So whats wrong??? Please advise friends as i have run out of ideas. |
#2 |
My Country: india
![]() No ideas?? or i'm not clear in my explanation of case?
#3 |
City & State: Ctg
My Country: Bangladesh
Line Voltage: 220VAC
![]() Its so difficult to find out .............laptop repair is tough work, sometimes its bother me
#4 |
City & State: Salamina
My Country: Greece
I'm a: Knowledge Seeker
![]() https://www.youtube.com/watch?v=rifMj6ne920
Check this video you might find it useful and get some more clues... |
#5 |
City & State: roma
My Country: italy
Line Voltage: 220 V
![]() This is schematic and bios dump,
have you a short on 3.3v <-- EC ? Last edited by jasko_jacker; 08-12-2017 at 10:42 AM.. |
#6 |
My Country: india
#7 |
City & State: kerela
My Country: indiia
![]() thanks
#8 |
City & State: mexico city
My Country: mexico
#9 |
City & State: anywhere
My Country: brazil
#10 |
City & State: roma
My Country: italy
Line Voltage: 220 V
![]() I remember a similar issue on a thinkpad solved with a pch reflow but in this case you should , In this case you should try to separate 3.3V 5V block from its loads
#11 |
City & State: Batticaloa
My Country: Srilanka
![]() Check at PL600 & PL601 for short circuit. And also PU600.
#12 |
My Country: india
#13 |
![]() i had the same issue on a motherboard. but i don't remember which resistor is damaged. so check resistors around pu200.
#14 |
City & State: Mardan
My Country: Pakistan
![]() check RE4 and RE1
#15 |
JIJUnMedia
City & State: kerala
My Country: india
Line Voltage: 230vac 50hz
![]() dears i have a problem dell 15-3521la-9104p)
it showing the massage battery not identifed system unable to charge i change battery ,charger chargig ic 3,5 ic all starting /charging mosfets near charging ic components pch bios 32/io,bios16 bios programmed io chip kb012qf changed and programmed but no chance please help me friends |
#16 | |
My Country: india
![]() Quote:
#17 |
My Country: india
![]() Can u run the laptop only on charged battery?? Check for shorted caps on battery output lines. What about PS_ID??
#18 |
City & State: konya
My Country: TÜRKİYE
![]() thanks
#19 |
City & State: MANIZALES
My Country: COLOMBIA
![]() thanks
#20 |
City & State: rome
My Country: italy
![]() Thank you
Thread Tools | |
Display Modes | |
