Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools
Old 02-02-2014, 12:02 PM   #1721
holmes222
City & State: goldwater town
My Country: INA
Line Voltage: 220v
I'm a: Knowledge Seeker
Default Re: Power supply build quality pictorial. part 2
found this psu in old NEC MY28V/R-G case .. its ACBEL API4PC17 non-PFC rated @250w 110v (TFX based psu)
this been converted to 220v , use this psu to powering my ubuntu proxy machine
main caps : nippon chemi-con SMG
other caps are nippon chemi-con KY, rubcon YXA,YXH
fan made by protechnic MGA8012HB-A25
i get this case with psu included for about 5$ here and the local shop have plenty stock
holmes222 is offline   Reply With Quote
Old 02-04-2014, 03:34 PM   #1722
Pentium4
CapXon Be Gone
Pentium4's Avatar
City & State: Idaho
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Logisys AT750BK
^ Looks good! Love those copper heatsinks
So right here might just be the only reliable Logisys PSU on planet earth? I was surprised to see this in a customers computer. I got to keep it and recapped it
It was 80 Plus certified, but I have doubts it can actually do 750W. I could be wrong though. Those heatsinks just don't look good enough unless that fan was really moving air. I think most of the parts seem capable though.
It's got good input filtering. 5 Y caps, 3 0.22µF X caps, 2 coils, but no MOV
PFC cap is Panasonic CE 390µF 400V
Bridge rectifier is on the heatsink and rated for 15A
PFC FET is Infineon 24N60C3 (TO-247) rated for 24.3A @ 25C and 15.4A @ 100C
PFC Diode is MOSPEC U15A60 (15A)
Switching FETs are Infineon 20N60C3's rated for 20.7A @ 25C and 13.1A @ 100C
Primary IC is a Fairchild BH0170
Secondary silicon:
3.3V = STPS40L45CW
5V = STPS40L45CW
12V = Two S40D45CS's in parallel
Secondary IC is a Weltrend WT7502V
Fan spins well and has plenty of oil, looks like a differently styled BaoDiKai fan that are often found in Logisys PSU's. This kinda looks like a YueLin to me, but I'm not quite sure...Is it maybe Keerda like most Logisys?
Original caps were BH and GL. Really glad I recapped it, on the primary there was a 22µF GL cap physically touching a resistor AND the primary heatsink! Can't imagine it would have lasted a long time.
Does this look capable of 750W?
Pentium4 is offline   Reply With Quote
Old 02-04-2014, 04:05 PM   #1723
goodpsusearch
City & State: Thessaloniki, Greece
My Country: Greece
Line Voltage: 230VAC 50Hz
Can't say for sure.
62A * 12V = 744W for 12V. I don't think it can output those watts, just look at the main toroid coil. It depends on the fan control circuit. Is it one of those completely "silent fan" designs? Then, I am quite sure the coil will cook itself if someone asks those watts from it. I always mod that circuit when needed.
But, I think it can output 40A or more on 12V and that is great anyway. I would keep it.
goodpsusearch is offline   Reply With Quote
Old 02-04-2014, 04:33 PM   #1724
Pentium4
CapXon Be Gone
Pentium4's Avatar
City & State: Idaho
My Country: USA
Yeah, the main toroid isn't small, but doesn't look good for 750W. Just to give you an idea cause it's hard to tell from the pics, the coil is 40mm tall, 15mm wide, 40mm length. At idle, the fan spins very slow. I loaded it up to 275W and the fan revved up a noticeable amount after about 30 seconds.
Old 02-04-2014, 04:45 PM   #1725
goodpsusearch
My Country: Greece
Put it in the most energy consuming PC you can set up (I use a Pentium D 2.66 with dynamic overclocking up to 3.2GHZ & gforce 7600 gt), disable PC case fans and let it run like that for 40minutes. Check periodically with your hand the air that comes out of the psu. Then, stop the PC and immediately put out psu and touch the secondary heatsink (NOT THE PRIMARY!) and the toroid coils. If they are too hot to touch for even a fraction of a second, I doubt it will be able to do its full rating for more than a couple of minutes..
Old 02-04-2014, 04:48 PM   #1726
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Those switchers would be capable of 750W. The Dell H750P-00 uses the same switches on an even smaller primary heat sink, and managed 900W on the load tester. But yeah, the secondary side could be a problem. Logisys have also been known to use fake 80plus badges on their PSUs.
__________________
c_hegge is offline   Reply With Quote
Old 02-04-2014, 06:36 PM   #1727
Pentium4
CapXon Be Gone
Pentium4's Avatar
City & State: Idaho
My Country: USA
Quote:
Will do. I have a Prescott P4 and a 8800 GTS OC
Quote:
I thought so too about the fake 80 Plus but it looks legitimate: http://www.plugloadsolutions.com/psu...50W_Report.pdf
Old 02-04-2014, 08:08 PM   #1728
Behemot
Behemot's Avatar
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
If it is truly certified, than it has to provide the power - they load it up to 100 %. Well, at least the units they obtain for certification
__________________
Behemot is offline   Reply With Quote
Old 02-04-2014, 08:09 PM   #1729
lti
lti's Avatar
City & State: Windsor, Colorado
My Country: United States
I'm a: Hobbyist Tech
It may be a real an 80 Plus Bronze rated 750W PSU, but there are only two crappy caps on each rail for filtering. I don't see any pi filter inductors. I don't think the ripple will be very low.
lti is offline   Reply With Quote
Old 02-04-2014, 08:41 PM   #1730
Pentium4
CapXon Be Gone
Pentium4's Avatar
City & State: Idaho
My Country: USA
Quote:
Good point See your caps there on the 12V rail?
Quote:
Yeah, forgot to mention that but you can easily see in the pictures...At least it's double forward so the design creates less ripple than half bridge, but you're probably right. Not worried about the minor rails, but those two caps for the 12V are 3300µF. On some of c_hegge's reviews, a low end half bridge unit kept ripple in spec up to 250W with a single filtering cap and no PI filter, so I imagine with this newer design and two caps, I'd expect ripple to be in spec at least up to 500W. Wouldn't really want to go higher continuously anyways. Wish I had a load tester
Old 02-08-2014, 11:53 AM   #1731
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Default Re: Logisys AT750BK
Quote:
For a fraction of a second before the fuse blows... maybe
I think goodpsusearch and lti mentioned some good points.
Without the pi coils, I don't think you can go too high. Maybe 500W like you said, or maybe less (but not more). Also, I don't know if it's the picture or not, but the wires on that secondary torroid don't look that thick. The torroid itself looks big enoughm though.
And finally, with just a single S40D45CS, the 12V rail will be (safely) capable of probably no more than 30 to 35A. So with two in parallel, it might be able to deliver up to 45A, but I wouldn't push it that far. Ripple at that point will probably start to dance around quite a bit too.
But other than that, it looks good. I think it will power a high-end system just fine as long as you have only one graphics card. And for a free-bee, it's definitely a nice score!
Old 02-08-2014, 01:47 PM   #1732
Behemot
Behemot's Avatar
My Country: CZ
Have you even noticed it is 80 PLUS Bronze certfied? You guys are sometimes frozen back in middle 90s when 400W PSUs had shitload of components inside and weighted like a ton. Nowadays PSUs do 1000 watts with barely any components in there, I have seen ATNG (or something similar)-made PSU which judged by you would barely make 400 watts, it did 650 or something and had 80 PLUS Bronze certification. OFC, you cannot run that at 100% capacity for years but weeks or months woud be OK. Not any „fraction of a second“ or another BS of yours.
They had to provide at least two units for testing and pay not really small fees, do you think they sent different units for that just to obtain the certification and paid the fees? That's just insane. I have been dealing with one company around, they will never pay the amount required for licensing and neither will do any other manufacturer. They may be selling cheap crap by milions but also have tiny income per unit, they won't sell that much extra units having the sticker on to justify the money for licensing.
Just my 2 cents cause whats enough is enough, sometimes I have the feeling anything is crap cause it will burn for sure according to you. Open your eyes, it's not always that case.
Old 02-08-2014, 10:48 PM   #1733
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
Line Voltage: 0-120VAC 60Hz
Secondary silicon:
3.3V = STPS40L45CW
5V = STPS40L45CW
LYP part number = LongYi Power. LongYi made a lot of the cheaper Coolmax units. They are good at ripping off Delta and Hipro designs, and screwing them up a bit in the process.
__________________
370forlife is offline   Reply With Quote
Old 02-09-2014, 12:23 AM   #1734
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
AcBel makes some pretty legit PSU's... And unlike some, this one has good caps. Great score.
__________________
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 02-10-2014, 07:34 PM   #1735
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Sorry. I'm just spoiled by those older 250W HiPro, Delta, Newton, and LiteON units, which now I can get ay my local Micro Center for $5 each. Yeah, they may do 300W or 350W fine... But they weren't labeled that way - and for a good reason so that damn thing lasts.
That, I don't like there. If I build something, I want it to last and not have to touch it, even if stressed at or near 100% capacity. Those HiPros are an example of that. I've worked with enough OEM PCs to stand by that. Yes, I am in the stone ages, sorry .
Yet they can't be bothered to get a UL or CSA certification . Hmmm, ain't that strange now? Heck, even the other certifications look forged to me. But who cares, it's 80 PLUS Bronze .
Hey come on, I wasn't that negative with my post above.
Just said you can't expect to pull 62A from it on the 12V rail. Not long term anyways.
Now on a serious note - okay I agree with you somewhat.... if that 80+ cert is real and they really paid to get it, then maybe this PSU is alright. But to me, it just looks like things would be running on the edge if you were to load things to the max according to the label.
Old 02-11-2014, 02:28 AM   #1736
Behemot
Behemot's Avatar
My Country: CZ
I am not saying it is anything wonderfull, I wouldn't touch it without protecting gloves, but it's not crap which will set your balls on fire either.
Old 02-14-2014, 01:58 PM   #1737
Dan81
SNES-powered
Dan81's Avatar
City & State: Bacau
My Country: Romania
Okay.....I've got a Delux ATX-400W P4 PSU.
I have two questions about it:
1.ALL,I mean ALL voltages are in their ranges,even if caps are CapXon.How does that happen?None of those caps are bulged.
2.How long do those CapXon caps last?It's been 1 year since I have this PSU.(I had to move this PSU's innards in a new case (Codegen 350W) )
Dan81 is offline   Reply With Quote
Old 02-14-2014, 03:16 PM   #1738
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Even bad quality capacitors like CapXon work fine when they are new. The problem is they just don't last very long.
Measuring voltages does not give much information aside from serious problems. When the capacitors are beginning to fail you would notice increased noise\ripple if you looked at the output with an oscilloscope. You will NOT normally notice anything obviously wrong if you just measure with a digital multimeter or look at voltage readings in BIOS or with software.
Voltmeter and BIOS readings don't update fast enough to be of much use. The noise and ripple you need to measure is in kHz range.
By the time the voltage readings go out of whack, the PSU and its capacitors are seriously sick.
If your PSU has not been loaded much, has been kept cool, and is after all, only 1 year old, it's not really a surprise that even some CapXon may still be OK.
Personally, I wouldn't worry about how long they are going to last, I'd rip them out and replace them before they had a chance to fail. But depending on the PSU, it may not be worth it. IIRC the last Delux PSU I was not exactly what you would call high quality.
__________________
-David VanHorn
Agent24 is offline   Reply With Quote
Old 02-15-2014, 01:37 AM   #1739
Dan81
SNES-powered
Dan81's Avatar
City & State: Bacau
My Country: Romania
It sees light use (3 hours max)so maybe that's why.
System it runs is a Celeron D 330,so not that power hungry considering the motherboard in there doesn't use the 12V 4 pin plug.
However my main PC uses a Delux ATX-450W PSU that is 6 years old.
This one has some caps marked with the Saturn planet and a S on them (what brand is this?),and they have black tops.I came across those caps on a old AT PSU too.
So far I had to replace just the motherboad because of a bad BIOS flash.Is it me or this one can last longer?
I only had to replace the fan so far,because the fan that came with it was on its last legs.Now it runs fine,without a problem.
This one,unlike the 400W PSU,is used 6 hours daylight and 7 hours night.
Also,I seen somewhere on this forum that fan controllers make the PSU overheat.Is this true?
Old 02-15-2014, 10:06 PM   #1740
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Is it the one with the green label? If so... i'd throw it away. It has a cheap fan that will wear out and no protection circuitry. Depending on your luck, it'll either fail gracefully due to capacitors gone bad, or it'll melt a trace and blow up everything connected to +5V and +3.3v.
Not fun. Seen one where the 12v went open circuit, and 5v went to 8.3v, 3.3v to 7.5v. Needless to say the motherboard and the hard drives didn't make it.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
