Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 07-09-2014, 02:13 AM   #1
Scootie
City & State: Satu Mare
My Country: Romania
Default Acer Aspire 5252 missing network(lan) in device manager
I got this laptop cheap from someone because the laptop didnt start up. The fix was easy, I had to reball the gpu. So far so good. After I installed a new windows I noticed that Im missing the network(lan) from device manager, no matter how many times I hit refresh it wont show up. Wifi is okay.
Curios, both leds light up when I plug cable into the port.
Motherboard model is:
HannStar J
MV-4
94V-0
or PEW96 LA-6552P.
Scootie is offline   Reply With Quote
Old 07-09-2014, 02:58 AM   #2
fddizon
City & State: Forbidden
My Country: Philippines
Line Voltage: 220v 60Hz
Default Re: Acer Aspire 5252 missing network(lan) in device manager
try this schema
fddizon is offline   Reply With Quote
Old 07-09-2014, 03:01 AM   #3
Scootie
My Country: Romania
Yes, thank you but already found the schematic. Lan circuits are on pg 24-25 and im trying to figure out how to interpret them. Truth to tell, it's the first time I dwell really into schematic reading.
Old 07-09-2014, 03:13 AM   #4
dellxps15
City & State: Italy
My Country: italy
try plug a cable on laptop and see if lan comes in
dellxps15 is offline   Reply With Quote
Old 07-09-2014, 03:52 AM   #5
Scootie
My Country: Romania
Nothing happens.
I managed to read and check all voltages from p.24. They all check, tough instead of 3V i have 3.3V but I dont think that matters.
However I noticed that there is a slight discolour on the lan chip(lower right corner) as shown in the picture, which I could'nt clean away. I check the voltages around and some pins had 1.2V, 3.3V, less then 1V or nothing on them. Im not sure that counts for something.
Old 07-09-2014, 04:59 AM   #6
dspok
City & State: Sudurpaschim
My Country: Nepal
Line Voltage: 220V
@Scootie
Did you check LAN config if it is enabled in BIOS?
dspok is offline   Reply With Quote
Old 07-09-2014, 05:02 AM   #7
Scootie
My Country: Romania
Yes, it is enabled, the bios was also reset(baterry out).
Old 07-09-2014, 05:09 AM   #8
dspok
My Country: Nepal
Line Voltage: 220V
@Scootie
I would like you run Linux Live CD & see if LAN works (to be sure).
Old 07-09-2014, 05:48 AM   #9
dellxps15
City & State: Italy
My Country: italy
try with linux. did the computer got hit by a flash (the one when there is bad wheater)
Old 07-09-2014, 07:11 AM   #10
Scootie
My Country: Romania
Hmm, bad news. Original problem has returned. Laptop starts but no video signal on screen or external vga is present. At one point from some reason it started, I got into bios to check again network status but the only option for t is a network boot rom which I enabled but still no presence of it in device manager while in windows, the green(only) light still lights up while cable is inserted.
Meanwhile, im downloading a livecd of knopix.
The gpu is a 216-0752001. Anyone knows if these have problems? I will try to reball it monday when I return to work.
Old 07-09-2014, 07:52 AM   #11
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
That NB/IGP is questionable indeed. However, i've done many of them and they all have one thing in common - very small pads on the mainboard. Maybe you didn't clean it thoroughly and some dirt or oxide was left on some of them, causing an intermittent connection.
The LAN is connected to the southbridge however - i suspect that board may have other issues as well. Has the laptop been dropped?
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 07-09-2014, 09:52 AM   #12
Scootie
My Country: Romania
That could be, Ill be back next Monday.
Old 11-25-2020, 05:15 AM   #13
Chieftain
City & State: Athens
My Country: Greece
Network problem is unfortunently from KB926QF... reprogramme (if you have programmer for this) or replace it.
Chieftain is offline   Reply With Quote
Old 11-25-2020, 05:55 AM   #14
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
KB926QF is not programmable my friend.
mcplslg123 is offline   Reply With Quote
Old 11-25-2020, 11:59 PM   #15
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
I'm a: Hobbyist Tech
did u check enabling options in bios?
ktmmotocross is offline   Reply With Quote
Old 11-26-2020, 07:08 AM   #16
piernov
City & State: Valbonne, 06
My Country: France
The last post from the OP was 6 years old.
piernov is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
