Dell15R-5521(LA-9101P) Bios need urgent
    hi guys i need Dell15R-5521(LA-9101P) bios this is my old but have password plz as soon as you can do guys thanks in advance
    Re: Dell15R-5521(LA-9101P) Bios need urgent
    Firmware BIOS does not help to remove the password
    Master password on the BIOS, boot and hard disk is calculated from a unique 16 digit code System Disable which can be seen if you enter 3 wrong password.
    Once the master password is set press the ENTER key and the password is deleted.
      i already try give 3 time wrong password then he give system disable [5AF50B8BA3E52C80] and also give service tag [4P1ZGW1] when i give his service tag to bios-pw.org then he give passwrod but they not working.
        this is latest A12 bios for your model.
        backup your old one & try attached.
        flash both bios.
          did this work?
            Originally posted by spike888ph View Post
            did this work?
            no password in bios chip you change the ene kb9012-a3 ic chip. your password after change chip finish
              i need dell vaw01 la-9101p both 2 and 4 mb bios
                use this
                  DELL İnspirion 5521 need bios
                  Hi
                  Need bios dump
                  DELL İnspirion 5521
                  VAW01 LA-9101P REV 1.0 (A00)
                  thanks.
                    Re: DELL İnspirion 5521 need bios
                    try this
                      Originally posted by kadi144 View Post
                      try this
                      Thanks bro is working
                        Thank
                        dump files ok
                          Thank you brother
                            after clenme it works thanks
                              thanks
                                thanks
                                  thx
                                    Thanks mate.. I confirm that it posts ok LA-9101p rev 1 on Dell P28F (3537) but sometimes I can't access bios menu
                                      hi guys
                                      i need Dell15R-5521(LA-9101P) BIOS working one with clean me Pl
                                      thanks in advance
                                        bios extras update site Dell..
