Need A15YA rev:2.1 BIOS Dump (Gigabyte Q2542)
  • MJ-meo-dmt
    • May 2016
    • 186
    • South Africa
    Looking for a BIOS Dump as per title.
    I found some MSI Boards tried those didn't work. Found a bios dump online for the same board but the bios was for the board that has a nvidia gpu chip.
    This board is CPU alone no GPU Chip
    EDIT: Old bios is fried... Tried dumping it only FFFFFFFF, 4MB of nothing
    while alive { live(toFullest=true) }
  • MJ-meo-dmt
    • May 2016
    • 186
    • South Africa
    Re: Need A15YA rev:2.1 BIOS Dump (Gigabyte Q2542)
    Nevermind... I got it from the Gigabyte site. They had it as P018_4M.203 file of 4096 in size... I just loaded that into my programmer and it worked just fine... Will try later versions in a few moments.
    Thanks anyways
    • Chieftain
      • May 2016
      • 72
      • Greece
      It could be nice if you can Upload it here , too...
      • peste
        • Dec 2016
        • 12371
        • ROMANIA
        https://www.badcaps.net/forum/showthread.php?t=71626
        • Habble7
          I need a BIOS dump for the Samsung S49CG934SU monitor
          by Habble7
          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
          Suspected Cause:
          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • DynaxSC
          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
          by DynaxSC
          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
          11-17-2023, 10:56 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          Hi everyone,
          I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
          BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
