ACLU1/ACLU2 UMA NM-A272 REV 1.0 problem
  • kalilinux25
    • Mar 2018
    • 2069
    • ZAMBOANGA SIBUGAY
    When I plug the DC charger the light indicator of the motherboard just blink and blink is anyone encounter this kind of problem? is there a way work around ?
    Thanks in advance
  • Chieftain
    • May 2016
    • 72
    • Greece
    Re: ACLU1/ACLU2 UMA NM-A272 REV 1.0 problem
    Your battery or psu must be replaced
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      You have not come up with any measurements.How can anybody help. Measure voltage on first 2 dc-in mosfets S-G-D.
      • Vebririon
        panasonic TX-P50V10E 6 blink led problem
        by Vebririon
        Hi everyone,
        I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
        Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
        I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
        05-17-2025, 10:16 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • dclass-pro
        Hp DAOP5FMB6A0 blink caps/lock problem
        by dclass-pro
        Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
        As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
        the battery was dead, i charged it and it works fine, but the pc won't turn on again.
        What do you recommend me? Do I have to redo the bios or is there anything else to check?...
        05-08-2023, 12:46 PM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
