Elitebook 1030 g2 beeps and fans spins after bios flash
    Hi
    I have trouble with hp x360 1030 g2 was trying to remove
    Bios password with the software i found on badcaps net and
    CH341A programmer i made backup but didn't verified it and after flashing it back laptop and turning it on only fans were spinning.
    Then other forum member sent me bios file for this laptop flashed it
    But now laptop only makes 3 long and 2 short beeps and fan spins at full speed also have tried different bios files from this form same thing.
    Any ideas how to fix it?
    Thank You
    Re: Elitebook 1030 g2 beeps and fans spins after bios flash
    I sent you a bios where you posted, maybe it helps.
      Thank you i will try it on monday
        Have tried the one you have posted no more beeps just fans are spinning and cap lock light on cannot get my head around
          Forgot to ask how long normally hp laptops starting after bios programming so should i wait for some time with laptop turned on or just try some different bios files because all it does fans spinning and nvme drive getting bit hot cpu is cool.
            Motherboard is 6050A284800-MB-A01
              did you get this problem solved? i need some help with same issue.
              TIA
                TIA
                Did you get it solved?
                  Have the same problem! Can you please send me bios too?
